I have been trying to install some software packages but I keep getting errors to do with linux-generic and linux-image-generic.
When running apt-get -f install this is the output, any help would be greatly appreciated:
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following extra packages will be installed:
  linux-generic linux-image-generic
The following packages will be upgraded:
2 upgraded, 0 newly installed, 0 to remove and 322 not upgraded.
2 not fully installed or removed.
Need to get 0 B/4,344 B of archives.
After this operation, 2,048 B of additional disk space will be used.
Do you want to continue [Y/n]? y
dpkg: dependency problems prevent configuration of linux-image-generic:
 linux-image-generic depends on linux-image-3.2.0-84-generic; however:
  Package linux-image-3.2.0-84-generic is not installed.
dpkg: error processing linux-image-generic (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of linux-generic:
 linux-generic depends on linux-image-generic (= 3.2.0.84.98); however:
  Package linux-image-generic is not configured yet.
 linux-generic depends on linux-headers-generic (= 3.2.0.84.98); however:
  Version of linux-headers-generic on system is 3.2.0.126.141.
dpkg: error processing linux-generic (--configure):
No apport report written because MaxReports has already been reached
No apport
 linux-image-generic
 linux-generic
fkraiem the output of apt-cache policy linux-generic linux-image-generic is:
  linux-generic:
      Installed: 3.2.0.84.98
      Candidate: 3.2.0.126.141
      Version table:
         3.2.0.126.141 0
            500 http://gb.archive.ubuntu.com/ubuntu/ precise-updates/main amd64 Packages
            500 http://security.ubuntu.com/ubuntu/ precise-security/main amd64 Packages
     *** 3.2.0.84.98 0
            100 /var/lib/dpkg/status
         3.2.0.23.25 0
            500 http://gb.archive.ubuntu.com/ubuntu/ precise/main amd64 Packages
      Version table:
         3.2.0.126.141 0
     *** 3.2.0.84.98 0
         3.2.0.23.25 0
Elder Geek the ouput of dpkg --configure -a is:
     linux-image-generic
     linux-generic
r1ck111
I have similar dependency issues on RHEL systems when the kernel and linux-firmware packages are out of date. Have you recently updated/upgraded your Ubuntu install? If not,
sudo apt update && apt upgrade
should suffice to get your system up to date; once that has run through, restart your system and try the install again.
Foxie
  • 551
The suggestion from Noisy_Botnet's link (mentioned in their comment) seemed to solve the problem:
sudo dpkg -r linux-generic linux-image-generic
sudo apt-get install linux-generic
matigo
  • 24,752
  • 50
  • 79
r1ck111
