There is an example service shell script in the download, but it seems limited and relies on killproc which doesn't exist by default on Ubuntu 16 LTS.
Walf
  • 452
Ubuntu 16 LTS uses systemd as the init system. This assumes you have already downloaded & installed the noip2 update client.
  1. Create the file /etc/systemd/system/noip2.service as follows:
    [Unit]
    Description=No-Ip Dynamic DNS Update Service
    After=network.target
    [Service]
    Type=forking
    ExecStart=/usr/local/bin/noip2
    [Install]
    WantedBy=multi-user.target
  2. Reload the init daemon:
    sudo systemctl daemon-reload
  3. Enable the service:
    sudo systemctl enable noip2
  4. Start the service:
    sudo systemctl start noip2
Derived from this readme
mrtumnus
  • 320
I used the sysvinit guide from Jonas Friedmann.
  1. Download and untar the No-IP DUC:
    wget https://www.noip.com/client/linux/noip-duc-linux.tar.gz
    tar -xf noip-duc-linux.tar.gz --exclude='._*' (excludes Mac dotfiles)
  2. Make and install it:
    cd noip-x.y (where x.y is version)
    make (errors here may mean you're missing compilation packages)
    sudo make install
  3. Create the file /etc/init.d/noip with these contents:
    #!/bin/sh
    ### BEGIN INIT INFO
    # Provides:          noip
    # Required-Start:    $local_fs $network $syslog
    # Required-Stop:     $local_fs $network $syslog
    # Default-Start:     2 3 4 5
    # Default-Stop:      0 1 6
    # Short-Description: no-ip DUC
    # Description:       Update DNS for dynamic IP on noip.com
    ### END INIT INFO
    NAME="noip"
    PATH="/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin"
    APPDIR="/"
    APPBIN="/usr/local/bin/noip2"
    PIDFILE="/var/run/${NAME}-customservice.pid"
    # Include functions
    set -e
    . /lib/lsb/init-functions
    start() {
        printf "Starting '$NAME'... "
        start-stop-daemon --start --background --make-pidfile --pidfile "$PIDFILE" --chdir "$APPDIR" --exec "$APPBIN" || true
        printf "done\n"
    #We need this function to ensure the whole process tree will be killed
    killtree() {
        local _pid=$1
        local _sig=${2-TERM}
        for _child in $(ps -o pid --no-headers --ppid ${_pid}); do
            killtree ${_child} ${_sig}
        done
        kill -${_sig} ${_pid}
    stop() {
        printf "Stopping '$NAME'... "
        [ -z `cat "$PIDFILE" 2>/dev/null` ] || \
            while test -d /proc/$(cat "$PIDFILE"); do
                killtree $(cat "$PIDFILE") 15
                sleep 0.5
            done
        [ -z `cat "$PIDFILE" 2>/dev/null` ] || rm "$PIDFILE"
        printf "done\n"
    status() {
        "$APPBIN" -S
    configure() {
        "$APPBIN" -C
    case "$1" in
        start)
            start
        stop)
            stop
        restart)
            stop
            start
        status)
            status
        configure)
            configure
            echo "Usage: $NAME {start|stop|restart|status|configure}" >&2
            exit 1
    esac
    exit 0
    (I used sudo vim /etc/init.d/noip.)
  4. Make it executable:
    sudo chmod a+x /etc/init.d/noip
  5. Enable it:
    sudo update-rc.d noip defaults
  6. Configure it:
    sudo service noip configure
  7. Start it:
    sudo service noip start
  8. Check it:
    sudo service noip status
Feedback is welcome.
Walf
  • 452
