I have an Ubuntu server VPS with DigitalOcean. This Ubuntu server contains a very simple web server and website setup, and not much else. However, whenever I create an image of the droplet (using the DigitalOcean control panel) the size is always increasing. The last image is 13GB, up from 9GB a few weeks ago... 7GB ... 5GB... just a few months ago.
So the disk space is getting eaten up, and I'm not sure why.
The /var/ directory where the website and other related assets are, including all the log files, is only using 1.3GB. So apparently this is not the source of the problem.
how can i determine what is eating up this disk space? Yes, I known I can use du, etc., but the problem is I don't know what would normally and legitimately be taking up a lot of space and what wouldn't. I want to see where this expansion in disk usage is occurring so I can then investigate to see if I can purge old/unnecessary files.
can you tell me what directories/files on an ubuntu server typically need pruning over time to prevent wasted disk space like I am experiencing?
I have enabled automatic system security updates. Could this be contributing to the problem? How would I check this? Can I clean out old files? Where would they be?
