I am making a mangos WoW auto-configuration personal script and I need libboost to compile the application as it is now a requirement. My distro is:
mangos@mangos-VB:~/Documents/setup/UbuntuBatches/MaNGOS$ uname -a
Linux mangos-VB 4.4.0-66-lowlatency #87-Ubuntu SMP PREEMPT Fri Mar 3 `16:43:09 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux`
I have the following output when tried to install it:
mangos@mangos-VB:~/Documents/setup/UbuntuBatches/MaNGOS$ sudo apt-get install libboost-all-dev
Reading package lists... Done
Building dependency tree
libboost-all-dev : Depends: libboost-date-time-dev but it is not going to be installed
Depends: libboost-filesystem-dev but it is not going to be installed
Depends: libboost-iostreams-dev but it is not going to be installed
Depends: libboost-log-dev but it is not going to be installed
Depends: libboost-python-dev but it is not going to be installed
Depends: libboost-regex-dev but it is not going to be installed
Depends: libboost-system-dev but it is not going to be installed
Depends: libboost-thread-dev but it is not going to be installed
Depends: libboost-wave-dev but it is not going to be installed
mangos@mangos-VB:~/Documents/setup/UbuntuBatches/MaNGOS$ sudo apt-cache policy libboost-all-dev
libboost-all-dev:
Installed: (none)
Candidate: 1.58.0.1ubuntu1
Version table:
1.58.0.1ubuntu1 500
500 http://bg.archive.ubuntu.com/ubuntu xenial/universe amd64 Packages
