As much as I love Banshee for managing my library, its a bit slow (on my laptop) to use as a media player when I just fancy listening to a song and it also lacks the plugins for enhancing the sound which Audacious has. I was wondering if the music lens could be modified to still scan Banshee's library but to open the selected music in Audacious instead?
Asked
Active
Viewed 778 times
Select your default application as audacious.
The music lens by default searches banshee music database and opens files using default music player.
To change default application, search for system info in dash, go to default applications tab and select your desired application. An alternate way of doing this would be to right click the file, select properties, select 'Open with' tab, and choose default application.
Mahesh
- 13,026
If you are an Ubuntu 12.10 user, there is a music lens scope available for Audacious. To install it, enter the following commands into a Terminal:
sudo add-apt-repository ppa:markjtully/ppa
sudo apt-get update
sudo apt-get install unity-scope-audacious
Then, log out and log back in again.
Mark Tully
- 838
