I recently changed my password for my school network and I have not been able to connect to the Eduroam connections since then.
I am using Ubuntu 16.04.
Here are a few things I tried:
It worked just fine before I updated my password. Please note that I don't see any file named Eduroam if I cd to /etc/NetworkManager/system-connections which was suggested by many people in the posts that I read.
We use eduroam at the university where I work; I connect to it myself when our primary wifi is being awkward. If you've definitely removed the previous connections, try the following connection settings; this is lifted from our intranet so it's what we're telling students now:
Wireless Security: WPA & WPA2 Enterprise
Authentication: Protected EAP (PEAP)
Anonymous Identity: <leave blank>
CA Certificate: <see below>
PEAP version: Automatic
Inner authentication: MSCHAPv2
Username: <your full university username e.g. usercode@someuni.ac.uk>
Password: <your university password>
Under the CA Certificate field, select the folder Icon and navigate to the location of your certificate store.
In Ubuntu (and Linux Mint) this is located in /etc/ssl/certs
Select the QuoVadis_Root_CA_2.pem certificate.
Additionally, try waiting a little while for the password change to propagate, try your old password in case it didn't change properly (changing your password again can sometimes force these things to sync if they failed) and also see if you can connect using another device like your mobile phone, then you'll have a better idea of whether it's really your laptop or the credentials you're using.
Edit: As I've just found out, eduroam is not UK specific so my confidence in these settings being consistent across establishments is now somewhat diminished.
David S
  • 131
There should be a manual from your school to help you to connect to their network. I use the following instructions, but it might not be applicable to your school's network, because there are different settings for different networks.
  1. Go to the wireless settings for setting up the connection.
  2. Set:
    Wireless security: WPA and WPA2 Enterprise
    Authentication: Tunneled TLS
    CA Certificate: None
    Inner authentication: PAP
    Username/Password: YOUR USERNAME AND PASSWORD
  3. Ignore the warning about the Certificate Authority.
    If this instruction does not work for you, you have to search for a specific instruction from your school.
Unique
  • 175
  • 13
I just spend a couple of hours trying to troubleshoot my eduroam connection. To cut a long story short, the answer was to change from the Tunneled TLS to PEAP.
Try to look into your system logs to see whether you have the following messages:
wlan0: dissassociated from ab:cd:ef:gh:ij:kl (Reason: 23)
To check this, run the following command from terminal:
dmesg | grep "disassociated"
If yes, chances are that changing from TLS to PEAP will help.
January
  • 37,208
