I just bought a used Dell Inspiron Mini 1010...and when I hit the brightness buttons (F4 and F5) it does nothing. Is there a different way to adjust brightness, or how do I get these buttons to work! I have tried hitting it while holding down the FN key as well, and it does nothing, please help!
Asked
Active
Viewed 1,554 times
As you boot, at the grub menu, type e to edit the boot options.
On the linux (kernel) line, near quiet splash add nolapic
quiet splash nolapic
If that works, we can add it to the default boot options. Edit /etc/default/grub
# command line
sudo -e /etc/default/grub
#graphical
gksudo gedit /etc/default/grub
Change the GRUB_CMDLINE_LINUX_DEFAULT to read
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash nolapic"
Save your edit, then update grub
sudo update-grub
If nolapic does not work, try acpi_backlight=vendor
Panther
- 104,528
