19
I been thinking of anyone could guide me up, that in ubuntu 11.10 with gnome 3,
there is a option ctrl+alt+d to show the desktop by minimizing the current window.
What I was thinking was that if I press ctrl+alt+d it will lead to desktop screen and when I press again ctrl+alt+d to go back to my working window..
As of now it doesnt work in this way ..is there any way out to do that same
Alexandre
  • 1,968
ashish
  • 191
With Gnome Shell (17.10+)
The default keybind is Ctrl + Super + d. The setting is called Hide all normal windows
You can change it in Settings > Keyboard Shortcuts > Navigation:
screenshot
With Unity (before 17.10)
The patch is already released but if you still face that problem use the following:
  • Click your username on the top right of the screen and select System Settings.
  • Under Hardware click Keyboard.
  • Switch to the Shortcuts tab, and click Navigation in the left column. Scroll down and select Hide all normal windows which has a default value of Disabled.
screenshot
Lorenz Keel
  • 9,511
Achu
  • 21,407
In Ubuntu 12.04 beta2 (gnome-shell 3.4) you can press Super-D to show your desktop, and Super-D again to go back to your previous windows.
If you want a non-keyboard method, there's also the "Show desktop button" option.
Simply visit this link and click on the on/off slider near the top left corner, you'll be prompted to install the widget, and from then on you'll have a small "show desktop" icon next to "Activities in your menu". (Shown here in between my Activities menu and Google Chrome Indicator)
Gnome Shell Show-Desktop Widget
Very handy, IMHO.
Updated 25/09/2017 with the new extension compatible with the current version of GNOME Shell, as suggested by @stefan-hamke. The out-of-date original is here.
Pablo Bianchi
  • 17,371
John T
  • 425
Programmatic/CLI way to set the “Hide all normal windows” shorcut (in my case, to Super + D ), tested working on GNOME 45:
gsettings set org.gnome.desktop.wm.keybindings show-desktop "['<Super>d']"
You can launch this from terminal (Ctrl+Alt+T is default keybinding on Ubuntu) or put this in your set-up shell script.
Kata55
