10
My ~/Documents directory is a symlink:
nathan@nathan-desktop:~$ stat Documents
  File: Documents -> /mnt/nathan/extended/Documents
If I want to cd into the directory, I can type:
c d space D o c tab
...and tab completion will append uments to the end of cd Doc as expected. However, it does not append a trailing /, even though the symlink points to a directory.
Is there a way to make Bash do that?
Nathan Osman
  • 32,495
Enable the mark-symlinked-directories option for READLINE. There are few ways to do that:
  1. Customize your readline by putting commands in an .inputrc file:
    • Create or edit ~/.inputrc and add these lines:
      $include /etc/inputrc
      set mark-symlinked-directories on
    • Log-in/Log-out or press ctrl+x and ctrl+r to reload the settings.
  2. Customize your readline by putting commands in the .bashrc file (or in the .profile file):
    • Edit ~/.bashrc and add this line:
      bind 'set mark-symlinked-directories on'
    • Log-in/Log-out or source the file:
      source ~/.bashrc
  3. Customize the readline for all users by creating a .sh file into the directory /etc/profile.d:
    • Create a file /etc/profile.d/mark-symlinked-directories.sh which should looks like:
      #!/bin/sh
      Executable permissions to this file are not needed.
    • Log-in/Log-out. That's it.
Further reading:
One simple way that I found is double tab for completion:
c d space D o c tab tab
The first tab will append uments, the second one will append / and the third will print the list of contained directories.
pa4080
  • 30,621
