I'm having a problem booting Ubuntu 16.04 after using windows 10 (I have fast boot enabled). But, as i understand, it should work. This is my disk setup:
  • Windows Partition (OS and programs) <- not mounted in ubuntu
  • Shared Ntfs Partition (Stuff) <- auto-mounted in ubuntu as nfts-3g
  • Ubuntu Partition
As I get, Windows Fast Boot make some sort of "shutdown/hibernate" which leaves the disk in an unsafe state after shutting down. But should this affect my "SHARED PARTITION" too? Because, after I remove the auto mount in the /etc/fstab file, ubuntu boots normally. Once I enter, if i try to mount the disk, this pops up:
Error mounting /dev/sda8 at /media/pablo/7A02A0B456DA5406:
Command-line `mount -t "ntfs" -o
"uhelper=udisks2,nodev,nosuid,uid=1000,gid=1000" "/dev/sda8"
"/media/pablo/7A02A0B456DA5406"' exited with non-zero exit status 14:
The disk contains an unclean file system (0, 0). Metadata kept in
Windows cache, refused to mount. Failed to mount '/dev/sda8':
Operation not permitted The NTFS partition is in an unsafe state.
Please resume and shutdown Windows fully (no hibernation or fast
restarting), or mount the volume read-only with the 'ro' mount option.
Hope you can give me some ideas.
Thanks.
