13
My gcc compiles well, but clang fails with the following message:
clang -fopenmp=libomp -o main main.c
main.c:5:10: fatal error: 'omp.h' file not found
I also installed libomp5 package and changed flag to -fopenmp=libomp5 , though it didn't help either:
clang -fopenmp=libomp5 -o main main.c
clang: error: unsupported argument 'libomp5' to option 'fopenmp='
these recommendations didn't work.
Would be grateful for hints on installing necessary 16.04 specific packages and passing corresponding flags.
Zanna
  • 72,312
I had the same problem.
sudo apt install libomp-dev
Fixed it with Ubuntu 16.10
//test.c
#include "omp.h"
#include <stdio.h>
int main(void) {
  #pragma omp parallel
  printf("thread %d\n", omp_get_thread_num());
Then
clang test.c -fopenmp
./a.out
thread 0
thread 5
thread 2
thread 1
thread 7
thread 3
thread 4
thread 6
Also
clant-3.9 test.c -fopenmp
works.
GCC and Clang use different OpenMP runtime libraries : libgomp and libomp respectivly.
Clang's runtime is the LLVM OpenMP runtime which in turn is based on the Intel OpenMP runtime (which is open source). https://www.openmprtl.org/
On my system GCC installed omp.h at
/usr/lib/gcc/x86_64-linux-gnu/6/include/omp.h
and libomp-dev insalled omp.h at
/usr/include/omp.h
These are different header files which include different function definitions. It may be okay to use either header file for e.g. omp_get_wtime() but in general I think it's probably better to use the header file that corresponds to the runtime that is linked to.
Z boson
  • 487
It seems omp.h file doesn't exist in your system PATH. firstly try to locate omp.h file if you don't know where it is:
find / -name 'omp.h' -type f
And then run this command to compile your code:
clang -o main main.c -I/path/to/omp/folder
