Had windows before. Got memory management & bad header etc blue screen errors. Now using live Ubuntu persistent USB. Unable to copy large files(>1GB) in system ,it freezes the PC and had to force shutdown. Unable to install OS into hard disk from live USB ,it shows this error
the following file did not match it's source copy on the CD/DVD :
/target/lib/modules/4.2.0-16-generic/kernal/driver/media/USB/gspca/gspca_topro.ko
This is often due to a faulty CD/DVD or drive, or a faulty hard disk. It may help to clean the CD/DVD , to burn the CD/DVD at lower speed , to clean CD/DVD drive lens (cleaning kits are often available from electronic suppliers) to check whether hard disk is old one or in need of a replacement or to move the system to cooler environment
and some times
*Error no 5 Input/Output Error
. I am able to create folders and copy
small files into hard disk though
And the result of command lsblk is
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
loop1 7:1 0 852.1M 0 loop /rofs
sdb 8:16 1 14.3G 0 disk
└─sdb1 8:17 1 14.3G 0 part /cdrom
zram3 251:3 0 989.1M 0 disk [SWAP]
zram1 251:1 0 989.1M 0 disk [SWAP]
sr0 11:0 1 1024M 0 rom
loop0 7:0 0 4G 0 loop
sda 8:0 0 931.5G 0 disk
├─sda2 8:2 0 778.8G 0 part
└─sda1 8:1 0 152.8G 0 part /media/lubuntu/F517-6AFB
zram2 251:2 0 989.1M 0 disk [SWAP]
zram0 251:0 0 989.1M 0 disk [SWAP]
Output of mount is
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime) proc on /proc type proc (rw,nosuid,nodev,noexec,relatime) udev on /dev type devtmpfs (rw,nosuid,relatime,size=4035852k,nr_inodes=1008963,mode=755) devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000) tmpfs on /run type tmpfs (rw,nosuid,noexec,relatime,size=810292k,mode=755) /dev/sdb1 on /cdrom type vfat (rw,noatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro) /dev/loop1 on /rofs type squashfs (ro,noatime) aufs on / type aufs (rw,noatime,si=c1a4b3edf9c769cc) securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime) tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev) tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k) tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755) cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,release_agent=/lib/systemd/systemd-cgroups-agent,name=systemd) pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime) efivarfs on /sys/firmware/efi/efivars type efivarfs (rw,nosuid,nodev,noexec,relatime) cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio) cgroup on /sys/fs/cgroup/hugetlb type cgroup (rw,nosuid,nodev,noexec,relatime,hugetlb) cgroup on /sys/fs/cgroup/net_cls,net_prio type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls,net_prio) cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices) cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer) cgroup on /sys/fs/cgroup/pids type cgroup (rw,nosuid,nodev,noexec,relatime,pids) cgroup on /sys/fs/cgroup/perf_event type cgroup (rw,nosuid,nodev,noexec,relatime,perf_event) cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset) cgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,memory) cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct) systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=26,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=884) mqueue on /dev/mqueue type mqueue (rw,relatime) debugfs on /sys/kernel/debug type debugfs (rw,relatime) hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime) fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime) tmpfs on /tmp type tmpfs (rw,nosuid,nodev,relatime) tmpfs on /run/user/999 type tmpfs (rw,nosuid,nodev,relatime,size=810288k,mode=700,uid=999,gid=999) gvfsd-fuse on /run/user/999/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,relatime,user_id=999,group_id=999) /dev/sda1 on /media/lubuntu/F517-6AFB type vfat (rw,nosuid,nodev,relatime,uid=999,gid=999,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,showexec,utf8,flush,errors=remount-ro,uhelper=udisks2)
And i tried to copy a file which is about 1 gb from /home/lubuntu/Downloads to /media/lubuntu/F517-6AFB/DC which gave a freeze and i had to force shutdown the pc.
* sudo fsck /dev/sda1*
fsck from util-linux 2.28.2 fsck.fat 4.0 (2016-05-06) 0x41: Dirty bit is set. Fs was not properly unmounted and some data may be corrupt. 1) Remove dirty bit 2) No action
Your having trouble with /media/lubuntu/F517-6AFB which corresponds to /dev/sda1. If the drive is mounted unmount it by issuing the command umount /dev/sda1 then sudo fsck.vfat -a /dev/sda1 which will do an automatic repair of the filesystem utilizing the safest means possible.
You haven't defined what you mean by small files, but I should tell you that the FAT family of file systems has limitations regarding file size that make it a poor choice in many cases. FAT 32 is limited to files 4GB in size.
Other possibilities include a bad cable or damaged drive. You can confirm by testing it in another system. If the problem follows the device try replacing the cable on your USB device. If that fails, It's possible that the drive is good but the electronics in the USB enclosure are bad. You can confirm this by swapping enclosures, or connecting the drive directly to the internal connectors in a desktop. If the problem doesn't follow the drive, plug it into a different USB port (preferably on a different bus)
Elder Geek
  • 36,752
