bash: /home/pjotrs/.rvm/scripts/rvm: No such file or directory
E: Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
pjotrs@pjotrs-desktop:~$ sudo lsof /var/lib/dpkg/lock
lsof: WARNING: can't stat() fuse.gvfs-fuse-daemon file system /home/pjotrs/.gvfs
Output information may be incomplete.
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
update-ma 3440 root 56uW REG 8,1 0 14942841 /var/lib/dpkg/lock
pjotrs@pjotrs-desktop:~$ sudo kill -TERM 3440
pjotrs@pjotrs-desktop:~$ sudo apt-get upgrade
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these.
libc-l10n : Breaks: locales (< 2.21-1) but 2.13+git20120306-3 is installed
E: Unmet dependencies. Try using -f.
I am trying to install an upgrade. However it keeps coming up with the error above. How can I solve this?
