I have installed wine and installed Adobe Digital Editions (ADE 4.5). When I started the icon ADE 4.5 nothing happened. Only this old version ADE 1.7 worked. But ADE 1.7 does not work with my ebook reader, kobo aura edition 2.
I have Googled for help with "Adobe Digital Editions installations under Linux" But all information I find is old.
When using winetricks, I get You are using a 64-bit WINEPREFIX and a lot that I didn't understand.
Might it be a 32-bit / 64-bit problem or a wrong window version under wine causing the newest ADE 4.5.4 not to work?
I tried what you suggested, but I get E: Paket winehq-devel could not be found. The same with winehq-stable
It was the same when changing to standard sources: http://packages.linuxmint.com http://archive.ubuntu.com/ubuntu I have Linux Mint 18.1 Serena
Zanna
  • 72,312
According to the Wine Application Database Version 4.5 works well with the development version 2.5 of wine. Instruction on how to obtain and install this version is available here.
In a nutshell, the steps are as follows:
Preparation:
If you have previously installed a Wine package from another repository, please remove it and any packages that depend on it (e.g., wine-mono, wine-gecko, winetricks) before attempting to install the WineHQ packages, as they may cause dependency conflicts.
Your system will require Multiarch support
Add the repository:
wget https://dl.winehq.org/wine-builds/Release.key
sudo apt-key add Release.key
sudo apt-add-repository https://dl.winehq.org/wine-builds/ubuntu/
Update packages and install:
sudo apt-get update && sudo apt-get install --install-recommends winehq-devel
You will notice some differences between the distro packages and the winehq builds. For more on this see the details.
According to winehq Ubuntu Multiarch support is still incomplete, so there may be further hoops to jump through that I am unable to test at present. The most current information I could find on this topic can be found here
Sources:
https://appdb.winehq.org/objectManager.php?sClass=version&iId=33276
https://wiki.winehq.org/Ubuntu
dpkg: How to remove a package and all other packages depend on it?
https://askubuntu.com/a/736651/225694
https://wiki.ubuntu.com/MultiarchSpec
Elder Geek
  • 36,752
