I'm trying to get MySQL to work on my ubuntu server. It seems I ran into some errors and I've been trying to sort them out myself but I haven't had any success. I ran:
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install mysql-server
After the installation I tried to make sure it was turned on by doing sudo service mysql start which ended up in it saying
Job for mysql.service failed because the control process exited with error code. See "systemctl status mysql.service" and "journalctl -xe" for details.
I ran sudo service mysql status Which returned this:
● mysql.service - MySQL Community Server
Loaded: loaded (/lib/systemd/system/mysql.service; enabled; vendor preset: enabled)
Active: activating (start-post) (Result: exit-code) since Tue 2017-04-04 14:15:55 EEST; 12s ago
Process: 7451 ExecStart=/usr/sbin/mysqld (code=exited, status=1/FAILURE)
Process: 7448 ExecStartPre=/usr/share/mysql/mysql-systemd-start pre (code=exited, status=0/SUCCESS)
Main PID: 7451 (code=exited, status=1/FAILURE); : 7452 (mysql-systemd-s)
Tasks: 2
Memory: 1.0M
CPU: 245ms
CGroup: /system.slice/mysql.service
└─control
├─7452 /bin/bash /usr/share/mysql/mysql-systemd-start post
└─7483 sleep 1
If someone could help with this I would appreciate it.
EDIT1:
Here is the output of journalctl -xe after trying to start MySql:
-- Defined-By: systemd
-- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- Unit mysql.service has failed.
-- The result is failed.
Apr 04 15:34:21 ramireini systemd[1]: mysql.service: Unit entered failed state.
Apr 04 15:34:21 ramireini systemd[1]: mysql.service: Failed with result 'exit-code'.
Apr 04 15:34:22 ramireini systemd[1]: mysql.service: Service hold-off time over, scheduling restart.
Apr 04 15:34:22 ramireini systemd[1]: Stopped MySQL Community Server.
-- Subject: Unit mysql.service has finished shutting down
-- Unit mysql.service has finished shutting down.
Apr 04 15:34:22 ramireini systemd[1]: Starting MySQL Community Server...
-- Subject: Unit mysql.service has begun start-up
-- Unit mysql.service has begun starting up.
Apr 04 15:34:22 ramireini audit[21899]: AVC apparmor="DENIED" operation="open" profile="/usr/sbin/mysqld" name="/proc/21899/status" pid=21899 comm="mysqld" requested_mask="r" denied_mask="r" fsuid=115 ouid=115
Apr 04 15:34:22 ramireini kernel: audit: type=1400 audit(1491309262.116:1342): apparmor="DENIED" operation="open" profile="/usr/sbin/mysqld" name="/proc/21899/status" pid=21899 comm="mysqld" requested_mask="r" denied_mask="r" fsuid=115 o
Apr 04 15:34:22 ramireini kernel: audit: type=1400 audit(1491309262.116:1343): apparmor="DENIED" operation="open" profile="/usr/sbin/mysqld" name="/sys/devices/system/node/" pid=21899 comm="mysqld" requested_mask="r" denied_mask="r" fsui
Apr 04 15:34:22 ramireini kernel: audit: type=1400 audit(1491309262.116:1344): apparmor="DENIED" operation="open" profile="/usr/sbin/mysqld" name="/proc/21899/status" pid=21899 comm="mysqld" requested_mask="r" denied_mask="r" fsuid=115 o
Apr 04 15:34:22 ramireini audit[21899]: AVC apparmor="DENIED" operation="open" profile="/usr/sbin/mysqld" name="/sys/devices/system/node/" pid=21899 comm="mysqld" requested_mask="r" denied_mask="r" fsuid=115 ouid=0
Apr 04 15:34:22 ramireini systemd[1]: mysql.service: Main process exited, code=exited, status=1/FAILURE
Apr 04 15:34:23 ramireini sudo[21909]: root : TTY=pts/6 ; PWD=/ ; USER=root ; COMMAND=/usr/sbin/service mysql start
Apr 04 15:34:23 ramireini sudo[21909]: pam_unix(sudo:session): session opened for user root by root(uid=0)
Apr 04 15:34:52 ramireini systemd[1]: Failed to start MySQL Community Server.
-- Subject: Unit mysql.service has failed
Apr 04 15:34:52 ramireini systemd[1]: mysql.service: Unit entered failed state.
Apr 04 15:34:52 ramireini sudo[21909]: pam_unix(sudo:session): session closed for user root
Apr 04 15:34:52 ramireini systemd[1]: mysql.service: Failed with result 'exit-code'.
Apr 04 15:34:52 ramireini systemd[1]: mysql.service: Service hold-off time over, scheduling restart.
Apr 04 15:34:52 ramireini systemd[1]: Stopped MySQL Community Server.
Apr 04 15:34:52 ramireini systemd[1]: Starting MySQL Community Server...
Apr 04 15:34:52 ramireini audit[22008]: AVC apparmor="DENIED" operation="open" profile="/usr/sbin/mysqld" name="/proc/22008/status" pid=22008 comm="mysqld" requested_mask="r" denied_mask="r" fsuid=115 ouid=115
Apr 04 15:34:52 ramireini audit[22008]: AVC apparmor="DENIED" operation="open" profile="/usr/sbin/mysqld" name="/sys/devices/system/node/" pid=22008 comm="mysqld" requested_mask="r" denied_mask="r" fsuid=115 ouid=0
Apr 04 15:34:52 ramireini kernel: audit: type=1400 audit(1491309292.625:1345): apparmor="DENIED" operation="open" profile="/usr/sbin/mysqld" name="/proc/22008/status" pid=22008 comm="mysqld" requested_mask="r" denied_mask="r" fsuid=115 o
Apr 04 15:34:52 ramireini kernel: audit: type=1400 audit(1491309292.625:1346): apparmor="DENIED" operation="open" profile="/usr/sbin/mysqld" name="/sys/devices/system/node/" pid=22008 comm="mysqld" requested_mask="r" denied_mask="r" fsui
Apr 04 15:34:52 ramireini kernel: audit: type=1400 audit(1491309292.625:1347): apparmor="DENIED" operation="open" profile="/usr/sbin/mysqld" name="/proc/22008/status" pid=22008 comm="mysqld" requested_mask="r" denied_mask="r" fsuid=115 o
Apr 04 15:34:52 ramireini systemd[1]: mysql.service: Main process exited, code=exited, status=1/FAILURE
lines 2046-2106/2106 (END)
[weechat] 0:WeeChat 1.4- 1:HTML 2:CSS 3:PHP 4:SQL*
https://hastebin.com/kayazumili.txt
I put it all into hastebin so the gazillion lines can actually fit into there :p
EDIT2:
I went by the steps and during the re-install I noted these:
AppArmor parser error for /etc/apparmor.d/usr.sbin.mysqld in /etc/apparmor.d/usr.sbin.mysqld at line 9: Could not open 'abstractions/mysql'.
W: Operation was interrupted before it could finish.
Output of MySQL Install Command:
root@ramireini:~# sudo apt-get install mysql-server
Reading package lists... Done
Building dependency tree
The following additional packages will be installed:
libaio1 libcgi-fast-perl libcgi-pm-perl libencode-locale-perl libevent-core-2.0-5 libfcgi-perl libhtml-parser-perl libhtml-tagset-perl libhtml-template-perl libhttp-date-perl libhttp-message-perl
libio-html-perl liblwp-mediatypes-perl libtimedate-perl liburi-perl mysql-client-5.7 mysql-client-core-5.7 mysql-common mysql-server-5.7 mysql-server-core-5.7
Suggested packages:
libdata-dump-perl libipc-sharedcache-perl libwww-perl mailx tinyca
The following NEW packages will be installed:
libio-html-perl liblwp-mediatypes-perl libtimedate-perl liburi-perl mysql-client-5.7 mysql-client-core-5.7 mysql-common mysql-server mysql-server-5.7 mysql-server-core-5.7
0 upgraded, 21 newly installed, 0 to remove and 4 not upgraded.
Need to get 0 B/19.4 MB of archives.
After this operation, 163 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = (unset),
LC_ALL = (unset),
LC_TIME = "fi_FI.UTF-8",
LC_MONETARY = "fi_FI.UTF-8",
LC_ADDRESS = "fi_FI.UTF-8",
LC_TELEPHONE = "fi_FI.UTF-8",
LC_NAME = "fi_FI.UTF-8",
LC_MEASUREMENT = "fi_FI.UTF-8",
LC_IDENTIFICATION = "fi_FI.UTF-8",
LC_NUMERIC = "fi_FI.UTF-8",
LC_PAPER = "fi_FI.UTF-8",
LANG = "en_US.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to a fallback locale ("en_US.UTF-8").
locale: Cannot set LC_ALL to default locale: No such file or directory
Preconfiguring packages ...
/usr/bin/locale: Cannot set LC_ALL to default locale: No such file or directory
Selecting previously unselected package mysql-common.
(Reading database ... 119915 files and directories currently installed.)
Preparing to unpack .../mysql-common_5.7.17-0ubuntu0.16.04.1_all.deb ...
Unpacking mysql-common (5.7.17-0ubuntu0.16.04.1) ...
Selecting previously unselected package libaio1:amd64.
Preparing to unpack .../libaio1_0.3.110-2_amd64.deb ...
Unpacking libaio1:amd64 (0.3.110-2) ...
Selecting previously unselected package mysql-client-core-5.7.
Preparing to unpack .../mysql-client-core-5.7_5.7.17-0ubuntu0.16.04.1_amd64.deb ...
Unpacking mysql-client-core-5.7 (5.7.17-0ubuntu0.16.04.1) ...
Selecting previously unselected package mysql-client-5.7.
Preparing to unpack .../mysql-client-5.7_5.7.17-0ubuntu0.16.04.1_amd64.deb ...
Unpacking mysql-client-5.7 (5.7.17-0ubuntu0.16.04.1) ...
Selecting previously unselected package mysql-server-core-5.7.
Preparing to unpack .../mysql-server-core-5.7_5.7.17-0ubuntu0.16.04.1_amd64.deb ...
Unpacking mysql-server-core-5.7 (5.7.17-0ubuntu0.16.04.1) ...
Selecting previously unselected package libevent-core-2.0-5:amd64.
Preparing to unpack .../libevent-core-2.0-5_2.0.21-stable-2ubuntu0.16.04.1_amd64.deb ...
Unpacking libevent-core-2.0-5:amd64 (2.0.21-stable-2ubuntu0.16.04.1) ...
Processing triggers for libc-bin (2.23-0ubuntu7) ...
Processing triggers for man-db (2.7.5-1) ...
Setting up mysql-common (5.7.17-0ubuntu0.16.04.1) ...
update-alternatives: using /etc/mysql/my.cnf.fallback to provide /etc/mysql/my.cnf (my.cnf) in auto mode
Selecting previously unselected package mysql-server-5.7.
(Reading database ... 120084 files and directories currently installed.)
Preparing to unpack .../mysql-server-5.7_5.7.17-0ubuntu0.16.04.1_amd64.deb ...
Unpacking mysql-server-5.7 (5.7.17-0ubuntu0.16.04.1) ...
Selecting previously unselected package libhtml-tagset-perl.
Preparing to unpack .../libhtml-tagset-perl_3.20-2_all.deb ...
Unpacking libhtml-tagset-perl (3.20-2) ...
Selecting previously unselected package liburi-perl.
Preparing to unpack .../liburi-perl_1.71-1_all.deb ...
Unpacking liburi-perl (1.71-1) ...
Selecting previously unselected package libhtml-parser-perl.
Preparing to unpack .../libhtml-parser-perl_3.72-1_amd64.deb ...
Unpacking libhtml-parser-perl (3.72-1) ...
Selecting previously unselected package libcgi-pm-perl.
Preparing to unpack .../libcgi-pm-perl_4.26-1_all.deb ...
Unpacking libcgi-pm-perl (4.26-1) ...
Selecting previously unselected package libfcgi-perl.
Preparing to unpack .../libfcgi-perl_0.77-1build1_amd64.deb ...
Unpacking libfcgi-perl (0.77-1build1) ...
Selecting previously unselected package libcgi-fast-perl.
Preparing to unpack .../libcgi-fast-perl_1%3a2.10-1_all.deb ...
Unpacking libcgi-fast-perl (1:2.10-1) ...
Selecting previously unselected package libencode-locale-perl.
Preparing to unpack .../libencode-locale-perl_1.05-1_all.deb ...
Unpacking libencode-locale-perl (1.05-1) ...
Selecting previously unselected package libhtml-template-perl.
Preparing to unpack .../libhtml-template-perl_2.95-2_all.deb ...
Unpacking libhtml-template-perl (2.95-2) ...
Selecting previously unselected package libtimedate-perl.
Preparing to unpack .../libtimedate-perl_2.3000-2_all.deb ...
Unpacking libtimedate-perl (2.3000-2) ...
Selecting previously unselected package libhttp-date-perl.
Preparing to unpack .../libhttp-date-perl_6.02-1_all.deb ...
Unpacking libhttp-date-perl (6.02-1) ...
Selecting previously unselected package libio-html-perl.
Preparing to unpack .../libio-html-perl_1.001-1_all.deb ...
Unpacking libio-html-perl (1.001-1) ...
Selecting previously unselected package liblwp-mediatypes-perl.
Preparing to unpack .../liblwp-mediatypes-perl_6.02-1_all.deb ...
Unpacking liblwp-mediatypes-perl (6.02-1) ...
Selecting previously unselected package libhttp-message-perl.
Preparing to unpack .../libhttp-message-perl_6.11-1_all.deb ...
Unpacking libhttp-message-perl (6.11-1) ...
Selecting previously unselected package mysql-server.
Preparing to unpack .../mysql-server_5.7.17-0ubuntu0.16.04.1_all.deb ...
Unpacking mysql-server (5.7.17-0ubuntu0.16.04.1) ...
Processing triggers for systemd (229-4ubuntu16) ...
Processing triggers for ureadahead (0.100.0-19) ...
Setting up libaio1:amd64 (0.3.110-2) ...
Setting up mysql-client-core-5.7 (5.7.17-0ubuntu0.16.04.1) ...
Setting up mysql-client-5.7 (5.7.17-0ubuntu0.16.04.1) ...
Setting up mysql-server-core-5.7 (5.7.17-0ubuntu0.16.04.1) ...
Setting up libevent-core-2.0-5:amd64 (2.0.21-stable-2ubuntu0.16.04.1) ...
Setting up mysql-server-5.7 (5.7.17-0ubuntu0.16.04.1) ...
update-alternatives: using /etc/mysql/mysql.cnf to provide /etc/mysql/my.cnf (my.cnf) in auto mode
Renaming removed key_buffer and myisam-recover options (if present)
invoke-rc.d: initscript mysql, action "start" failed.
â— mysql.service - MySQL Community Server
Active: activating (auto-restart) (Result: exit-code) since Tue 2017-04-04 19:01:59 EEST; 21ms ago
Process: 25878 ExecStartPost=/usr/share/mysql/mysql-systemd-start post (code=exited, status=0/SUCCESS)
Process: 25877 ExecStart=/usr/sbin/mysqld (code=exited, status=1/FAILURE)
Process: 25872 ExecStartPre=/usr/share/mysql/mysql-systemd-start pre (code=exited, status=0/SUCCESS)
Main PID: 25877 (code=exited, status=1/FAILURE)
Apr 04 19:01:59 ramireini systemd[1]: Failed to start MySQL Community Server.
Apr 04 19:01:59 ramireini systemd[1]: mysql.service: Unit entered failed state.
Apr 04 19:01:59 ramireini systemd[1]: mysql.service: Failed with result 'exit-code'.
dpkg: error processing package mysql-server-5.7 (--configure):
subprocess installed post-installation script returned error exit status 1
Setting up libhtml-tagset-perl (3.20-2) ...
Setting up liburi-perl (1.71-1) ...
Setting up libhtml-parser-perl (3.72-1) ...
Setting up libcgi-pm-perl (4.26-1) ...
Setting up libfcgi-perl (0.77-1build1) ...
Setting up libcgi-fast-perl (1:2.10-1) ...
Setting up libencode-locale-perl (1.05-1) ...
Setting up libhtml-template-perl (2.95-2) ...
Setting up libtimedate-perl (2.3000-2) ...
Setting up libhttp-date-perl (6.02-1) ...
Setting up libio-html-perl (1.001-1) ...
Setting up liblwp-mediatypes-perl (6.02-1) ...
Setting up libhttp-message-perl (6.11-1) ...
dpkg: dependency problems prevent configuration of mysql-server:
mysql-server depends on mysql-server-5.7; however:
Package mysql-server-5.7 is not configured yet.
dpkg: error processing package mysql-server (--configure):
dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
mysql-server-5.7
mysql-server
root@ramireini:~#
Output of sudo apt -o Dpkg::Options::="--force-confmiss" install --reinstall mysql-server:
root@ramireini:/# sudo apt -o Dpkg::Options::="--force-confmiss" install --reinstall mysql-server
Suggested packages:
mailx tinyca
0 upgraded, 6 newly installed, 0 to remove and 4 not upgraded.
Need to get 0 B/18,7 MB of archives.
After this operation, 160 MB of additional disk space will be used.
(Reading database ... 89934 files and directories currently installed.)
Configuration file '/etc/mysql/conf.d/mysql.cnf', does not exist on system.
Installing new config file as you requested.
Configuration file '/etc/mysql/conf.d/mysqldump.cnf', does not exist on system.
Configuration file '/etc/mysql/my.cnf.fallback', does not exist on system.
(Reading database ... 90091 files and directories currently installed.)
Configuration file '/etc/apparmor.d/usr.sbin.mysqld', does not exist on system.
Configuration file '/etc/init.d/mysql', does not exist on system.
Configuration file '/etc/init/mysql.conf', does not exist on system.
Configuration file '/etc/logcheck/ignore.d.paranoid/mysql-server-5_7', does not exist on system.
Configuration file '/etc/logcheck/ignore.d.server/mysql-server-5_7', does not exist on system.
Configuration file '/etc/logcheck/ignore.d.workstation/mysql-server-5_7', does not exist on system.
Configuration file '/etc/logrotate.d/mysql-server', does not exist on system.
Configuration file '/etc/mysql/debian-start', does not exist on system.
Configuration file '/etc/mysql/mysql.cnf', does not exist on system.
Configuration file '/etc/mysql/mysql.conf.d/mysqld.cnf', does not exist on system.
Configuration file '/etc/mysql/mysql.conf.d/mysqld_safe_syslog.cnf', does not exist on system.
Active: activating (auto-restart) (Result: exit-code) since ti 2017-04-04 21:40:43 EEST; 16ms ago
Process: 3090 ExecStartPost=/usr/share/mysql/mysql-systemd-start post (code=exited, status=0/SUCCESS)
Process: 3089 ExecStart=/usr/sbin/mysqld (code=exited, status=1/FAILURE)
Process: 3085 ExecStartPre=/usr/share/mysql/mysql-systemd-start pre (code=exited, status=0/SUCCESS)
Main PID: 3089 (code=exited, status=1/FAILURE)
huhti 04 21:40:43 ramireini systemd[1]: Failed to start MySQL Community Server.
huhti 04 21:40:43 ramireini systemd[1]: mysql.service: Unit entered failed state.
huhti 04 21:40:43 ramireini systemd[1]: mysql.service: Failed with result 'exit-code'.
mysql-server-5.7
mysql-server
root@ramireini:/#
