I am using PPTP VPN connection on Ubuntu 16.04 and it is working fine after fresh boot and when I first establish connection. But if it get disconnected by some reason and I reconnect (it reports it reconnected successfully) it stops working - meaning I can not open any web page anymore, I get timeout for all connections.
I found temporary solution by restarting network manager as mentioned in this answer
sudo systemctl restart network-manager.service
This behaviour only started recently, like 2 weeks ago (maybe bug in one of the updates?), before I had no problems. VPN connection itself is not problematic since it works without problems on different OSs.
Same problem happens if I suspend and resume.
How can I debug and resolve this issue?
kovinet
  • 113
I came cross the exactly same problem after upgrading my Ubuntu 16.04.
I also found that the "disconnect VPN" button has disappeared after upgrade and "configure VPN" has become constantly gray.
At first i doubt if there's any issue with the NetworkManager package, thus i tried reinstalling all nm packages, but it didn't work.
Then i doubt if my system is corrupted, I even reinstalled the whole OS (only root folder) with newest stable release 16.04.02, but it neither worked.
I suspect that some update in 16.04.02 caused this problem. Really hope this problem could be solved soon.
Shaun
This happens to me as well (except with OpenVPN), and to fix it I used sudo killall dnsmasq. Unfortunately I have to do it every time I disconnect and reconnect to my vpn but its better than nothing!
EDIT: I found a solution. Go to the terminal and type
gksudo gedit /etc/NetworkManager/NetworkManager.conf
And comment out the line dns = dnsmasq
Here is the link for where I found this information https://bugs.launchpad.net/ubuntu/+source/network-manager/+bug/1633912
