I am working on an Eclipse project. Some of its SWT control is not working properly in Ubuntu 14.04 or 16.04.
I found by searching online that this issue is because of the latest GTK versions. The fix is executing the following command before starting the application via terminal export GDK_NATIVE_WINDOWS=true.
This worked for all of my colleagues but not my machine (Ubuntu 14.04). Why did it fail and how can I fix it?
Zanna
  • 72,312
Chinna
  • 41
I also had this problem. Normaly, it is solved (for me in Ubuntu 16.10) by
--launcher.GTK_version
before
--launcher.appendVmargs
See also: Eclipse not working in 16.04 If it does not work, it would be helpful to add your eclipse version, or maybe to try a newer/older version.
