48
I am trying to upgrade my nodejs to 7.6 but failed. Now I have a new problem after re-installing node 6.10:
$ sudo apt-get purge nodejs npm
Reading package lists... Done
Building dependency tree
Package 'npm' is not installed, so not removed
The following packages were automatically installed and are no longer required:
  linux-headers-4.8.0-40 linux-headers-4.8.0-40-generic linux-image-4.8.0-40-generic linux-image-extra-4.8.0-40-generic
Use 'sudo apt autoremove' to remove them.
The following packages will be REMOVED
  nodejs*
0 to upgrade, 0 to newly install, 1 to remove and 53 not to upgrade.
After this operation, 51.7 MB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database ... 278133 files and directories currently installed.)
Removing nodejs (6.9.5-1nodesource1~yakkety1) ...
Processing triggers for man-db (2.7.5-1) ...
(Reading database ... 274476 files and directories currently installed.)
Purging configuration files for nodejs (6.9.5-1nodesource1~yakkety1) ...
dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules' not empty so not removed
Why does it say Package 'npm' is not installed, so not removed? i have been using npm to install many node packages for my projects!!
I ignore the error and went on installing node 7.6:
$ curl -sL https://deb.nodesource.com/setup_7.6 | sudo -E bash -
bash: line 1: html: No such file or directory
bash: line 2: syntax error near unexpected token `<'
'ash: line 2: `<head><title>404 Not Found</title></head>
So I fell back to node 6.x. But I cannot install npm anymore:
$ sudo apt-get install npm
The following packages have unmet dependencies.
 npm : Depends: nodejs but it is not going to be installed
       Depends: node-abbrev (>= 1.0.4) but it is not going to be installed
       Depends: node-ansi (>= 0.3.0-2) but it is not going to be installed
       Depends: node-ansi-color-table but it is not going to be installed
       Depends: node-archy but it is not going to be installed
       Depends: node-block-stream but it is not going to be installed
       Depends: node-fstream (>= 0.1.22) but it is not going to be installed
       Depends: node-fstream-ignore but it is not going to be installed
       Depends: node-github-url-from-git but it is not going to be installed
       Depends: node-glob (>= 3.1.21) but it is not going to be installed
       Depends: node-graceful-fs (>= 2.0.0) but it is not going to be installed
       Depends: node-inherits but it is not going to be installed
       Depends: node-ini (>= 1.1.0) but it is not going to be installed
       Depends: node-lockfile but it is not going to be installed
       Depends: node-lru-cache (>= 2.3.0) but it is not going to be installed
       Depends: node-minimatch (>= 0.2.11) but it is not going to be installed
       Depends: node-mkdirp (>= 0.3.3) but it is not going to be installed
       Depends: node-gyp (>= 0.10.9) but it is not going to be installed
       Depends: node-nopt (>= 3.0.1) but it is not going to be installed
       Depends: node-npmlog but it is not going to be installed
       Depends: node-once but it is not going to be installed
       Depends: node-osenv but it is not going to be installed
       Depends: node-read but it is not going to be installed
       Depends: node-read-package-json (>= 1.1.0) but it is not going to be installed
       Depends: node-request (>= 2.25.0) but it is not going to be installed
       Depends: node-retry but it is not going to be installed
       Depends: node-rimraf (>= 2.2.2) but it is not going to be installed
       Depends: node-semver (>= 2.1.0) but it is not going to be installed
       Depends: node-sha but it is not going to be installed
       Depends: node-slide but it is not going to be installed
       Depends: node-tar (>= 0.1.18) but it is not going to be installed
       Depends: node-underscore but it is not going to be installed
       Depends: node-which but it is not going to be installed
Any ideas?
Run
  • 2,748
5 Answers5
63
I had the same issue with npm.
I suggest you install aptitude which can help you resolve conflicts
sudo apt install aptitude
then install your package with aptitude
sudo aptitude install npm
Zanna
  • 72,312
Shakirah
  • 731
62
I had the same issue with npm and had to install the following packages in order:
sudo apt install libssl1.0-dev
sudo apt install nodejs-dev
sudo apt install node-gyp
sudo apt install npm
Hope this helps
dvillaj
  • 729
sudo rm -rf /usr/local/bin/npm /usr/local/share/man/man1/node* ~/.npm
sudo rm -rf /usr/local/lib/node*
sudo rm -rf /usr/local/bin/node*
sudo rm -rf /usr/local/include/node*
sudo apt autoremove
Then install node and npm
You do not need to install npm when installing nodejs from nodesource, as it already includes npm.
The error you're getting is because there is no npm package in the nodesource repo, therefore trying to install npm will select the built-in npm package, which pulls the built-in (old) nodejs package.
Just do this, as described in the installation instructions:
curl -fsSL https://deb.nodesource.com/setup_22.x | sudo -E bash -
sudo apt-get install nodejs
It will install both node and npm.
node -v
npm -v
rustyx
  • 1,066
  • 15
  • 17
This works for me:
sudo aptitude install libnode-dev
sudo aptitude install libnode64
sudo aptitude install node-gyp
Saurabh Khanna
  • 181
