39
I have an emergency, Linux and Bash beginner here and messed up trying to write a script to rename some files. The loop accidentally went up the path (ran the script in a folder in Desktop) and renamed /bin to /D_bin (D_ was the prefix I added) so now the system can't use /bin contents, so no bash, no mv to rename, no sudo... The files in /D_bin are ok, not renamed, and can copy-paste them but can't create folder /bin again without bash. The system looks stable but very few things work and have no access to files in Desktop.
The other folders of / like /lib /sbin /etc seem to be ok too, and the graphical desktop is still there. I'm afraid of restarting because I don't know if it will be able to boot.
Is there a shell in root or a way to rename /D_bin back to /bin? Need help please, very important work compromised
My suicidal script :$ :
#!/bin/bash
files=~/Desktop/folder_1/*
for j in $files
do
    cd $j
    for i in 10n*  #file names starting by 10n
    do
       find * -maxdepth 0 ! -path . -exec mv {} D_{} \;
    done
    cd ..
done
:( Thanks!!!!
derHugo
  • 3,376
  • 34
  • 52
There are several ways to fix this issue.
If you have access to a shell (any open terminal), run:
sudo /D_bin/mv -T /D_bin /bin
sudo is in /usr/bin so there is no need to run it with absolute path.
The other thing you can do is, adding the /D_bin to your PATH environment variable, like this:
export PATH=$PATH:/D_bin
If you don't have access to any shell:
  1. reboot the system
  2. when grub appears press e to edit the grub
  3. at the end of the line which starts with linux, add:
    init=/D_bin/bash
  4. press CTRL+x
Now you will be dropped into a bash shell, you should remount file system as read and writable.
/D_bin/mount -o remount,rw /
And move the D_bin directory to bin:
Then reboot the system.
It should work, but if nothing worked for you, you still can boot the system with a live ubuntu disk/usb and fix the issue.
Ravexina
  • 57,256
To fix this problem if you have no running terminal open, I would first try to find a “shell substitute” that you can use instead of bash. Python is in /usr/bin, so that should still work.
Python 2.7.6 (default, Oct 26 2016, 20:30:19)
[GCC 4.8.4] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import subprocess
>>> subprocess.call(["sudo", "/D_bin/mv", "-T", "/D_bin", "/bin"])
If that doesn't work, I'd just straight boot from live CD / USB and fix everything from a known-sane running environment.
As a general advice, I'd second Jonathan Leffler in the comments: never use cd .. in scripts, it can easily lead to such problems. Better only cd into the $j directory within a subshell, this way you don't have to worry about getting back.
#!/bin/bash
for j in $files
do
    cd "$j"
    do
    done
done
Also, of course, don't run stuff as root unless absolutely necessary.
