i just want to set the maximum frequency of my cpu, it can go from 1.7GHz to 2.4GHz, i used cpufrequtils and tried "performance" and "userspace" but it didn't work. Here's is my cpufreq-info output:
It says "hardware limits: 768 MHz - 2.40 GHz" but then it says "current policy: frequency should be within 1.70 GHz and 1.70 GHz. The governor "userspace" may decide which speed to use within this range." so i don't know how to actually do it. I also found that maybe cpufrequtils will not work for my intel cpu using as default pstate
cpufrequtils 008: cpufreq-info (C) Dominik Brodowski 2004-2009
Report errors and bugs to cpufreq@vger.kernel.org, please.
analyzing CPU 0:
  driver: acpi-cpufreq
  CPUs which run at the same hardware frequency: 0
  CPUs which need to have their frequency coordinated by software: 0
  maximum transition latency: 10.0 us.
  available frequency steps: 2.40 GHz, 2.40 GHz, 2.30 GHz, 2.20 GHz, 2.00 GHz, 1.90 GHz, 1.70 GHz, 1.60 GHz, 1.50 GHz, 1.40 GHz, 1.30 GHz, 1.20 GHz, 1.10 GHz, 900 MHz, 800 MHz, 768 MHz
  available cpufreq governors: conservative, ondemand, userspace, powersave, performance
                  within this range.
  current CPU frequency is 1.70 GHz.
  cpufreq stats: 2.40 GHz:0,00%, 2.40 GHz:0,00%, 2.30 GHz:0,00%, 2.20 GHz:0,00%, 2.00 GHz:0,00%, 1.90 GHz:0,00%, 1.70 GHz:31,70%, 1.60 GHz:0,02%, 1.50 GHz:0,00%, 1.40 GHz:0,00%, 1.30 GHz:0,00%, 1.20 GHz:0,00%, 1.10 GHz:0,00%, 900 MHz:0,00%, 800 MHz:0,00%, 768 MHz:68,28%  (7)
analyzing CPU 1:
  CPUs which run at the same hardware frequency: 1
  CPUs which need to have their frequency coordinated by software: 1
  current policy: frequency should be within 768 MHz and 1.70 GHz.
                  The governor "performance" may decide which speed to use
                  within this range.
  cpufreq stats: 2.40 GHz:0,00%, 2.40 GHz:0,00%, 2.30 GHz:0,00%, 2.20 GHz:0,00%, 2.00 GHz:0,00%, 1.90 GHz:0,00%, 1.70 GHz:99,98%, 1.60 GHz:0,02%, 1.50 GHz:0,00%, 1.40 GHz:0,00%, 1.30 GHz:0,00%, 1.20 GHz:0,00%, 1.10 GHz:0,00%, 900 MHz:0,00%, 800 MHz:0,00%, 768 MHz:0,00%  (3)
analyzing CPU 2:
  CPUs which run at the same hardware frequency: 2
  CPUs which need to have their frequency coordinated by software: 2
                  within this range.
analyzing CPU 3:
  CPUs which run at the same hardware frequency: 3
  CPUs which need to have their frequency coordinated by software: 3
                  within this range.
This is what i get when i use "grep . /sys/devices/system/cpu/cpu*/cpufreq/*"
/sys/devices/system/cpu/cpu0/cpufreq/affected_cpus:0
/sys/devices/system/cpu/cpu0/cpufreq/bios_limit:1700000
/sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq:1700000
/sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freq:2401000
/sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_min_freq:768000
/sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_transition_latency:10000
/sys/devices/system/cpu/cpu0/cpufreq/freqdomain_cpus:0 1 2 3
/sys/devices/system/cpu/cpu0/cpufreq/related_cpus:0
/sys/devices/system/cpu/cpu0/cpufreq/scaling_available_frequencies:2401000 2400000 2300000 2200000 2000000 1900000 1700000 1600000 1500000 1400000 1300000 1200000 1100000 900000 800000 768000
/sys/devices/system/cpu/cpu0/cpufreq/scaling_available_governors:conservative ondemand userspace powersave performance
/sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq:1700000
/sys/devices/system/cpu/cpu0/cpufreq/scaling_driver:acpi-cpufreq
/sys/devices/system/cpu/cpu0/cpufreq/scaling_governor:userspace
/sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq:1700000
/sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq:1700000
/sys/devices/system/cpu/cpu0/cpufreq/scaling_setspeed:1700000
/sys/devices/system/cpu/cpu1/cpufreq/affected_cpus:1
/sys/devices/system/cpu/cpu1/cpufreq/bios_limit:1700000
/sys/devices/system/cpu/cpu1/cpufreq/cpuinfo_cur_freq:1700000
/sys/devices/system/cpu/cpu1/cpufreq/cpuinfo_max_freq:2401000
/sys/devices/system/cpu/cpu1/cpufreq/cpuinfo_min_freq:768000
/sys/devices/system/cpu/cpu1/cpufreq/cpuinfo_transition_latency:10000
/sys/devices/system/cpu/cpu1/cpufreq/freqdomain_cpus:0 1 2 3
/sys/devices/system/cpu/cpu1/cpufreq/related_cpus:1
/sys/devices/system/cpu/cpu1/cpufreq/scaling_available_frequencies:2401000 2400000 2300000 2200000 2000000 1900000 1700000 1600000 1500000 1400000 1300000 1200000 1100000 900000 800000 768000
/sys/devices/system/cpu/cpu1/cpufreq/scaling_available_governors:conservative ondemand userspace powersave performance
/sys/devices/system/cpu/cpu1/cpufreq/scaling_cur_freq:1700000
/sys/devices/system/cpu/cpu1/cpufreq/scaling_driver:acpi-cpufreq
/sys/devices/system/cpu/cpu1/cpufreq/scaling_governor:performance
/sys/devices/system/cpu/cpu1/cpufreq/scaling_max_freq:1700000
/sys/devices/system/cpu/cpu1/cpufreq/scaling_min_freq:768000
/sys/devices/system/cpu/cpu1/cpufreq/scaling_setspeed:<unsupported>
/sys/devices/system/cpu/cpu2/cpufreq/affected_cpus:2
/sys/devices/system/cpu/cpu2/cpufreq/bios_limit:1700000
/sys/devices/system/cpu/cpu2/cpufreq/cpuinfo_cur_freq:1700000
/sys/devices/system/cpu/cpu2/cpufreq/cpuinfo_max_freq:2401000
/sys/devices/system/cpu/cpu2/cpufreq/cpuinfo_min_freq:768000
/sys/devices/system/cpu/cpu2/cpufreq/cpuinfo_transition_latency:10000
/sys/devices/system/cpu/cpu2/cpufreq/freqdomain_cpus:0 1 2 3
/sys/devices/system/cpu/cpu2/cpufreq/related_cpus:2
/sys/devices/system/cpu/cpu2/cpufreq/scaling_available_frequencies:2401000 2400000 2300000 2200000 2000000 1900000 1700000 1600000 1500000 1400000 1300000 1200000 1100000 900000 800000 768000
/sys/devices/system/cpu/cpu2/cpufreq/scaling_available_governors:conservative ondemand userspace powersave performance
/sys/devices/system/cpu/cpu2/cpufreq/scaling_cur_freq:1700000
/sys/devices/system/cpu/cpu2/cpufreq/scaling_driver:acpi-cpufreq
/sys/devices/system/cpu/cpu2/cpufreq/scaling_governor:performance
/sys/devices/system/cpu/cpu2/cpufreq/scaling_max_freq:1700000
/sys/devices/system/cpu/cpu2/cpufreq/scaling_min_freq:768000
/sys/devices/system/cpu/cpu2/cpufreq/scaling_setspeed:<unsupported>
/sys/devices/system/cpu/cpu3/cpufreq/affected_cpus:3
/sys/devices/system/cpu/cpu3/cpufreq/bios_limit:1700000
/sys/devices/system/cpu/cpu3/cpufreq/cpuinfo_cur_freq:1700000
/sys/devices/system/cpu/cpu3/cpufreq/cpuinfo_max_freq:2401000
/sys/devices/system/cpu/cpu3/cpufreq/cpuinfo_min_freq:768000
/sys/devices/system/cpu/cpu3/cpufreq/cpuinfo_transition_latency:10000
/sys/devices/system/cpu/cpu3/cpufreq/freqdomain_cpus:0 1 2 3
/sys/devices/system/cpu/cpu3/cpufreq/related_cpus:3
/sys/devices/system/cpu/cpu3/cpufreq/scaling_available_frequencies:2401000 2400000 2300000 2200000 2000000 1900000 1700000 1600000 1500000 1400000 1300000 1200000 1100000 900000 800000 768000
/sys/devices/system/cpu/cpu3/cpufreq/scaling_available_governors:conservative ondemand userspace powersave performance
/sys/devices/system/cpu/cpu3/cpufreq/scaling_cur_freq:1700000
/sys/devices/system/cpu/cpu3/cpufreq/scaling_driver:acpi-cpufreq
/sys/devices/system/cpu/cpu3/cpufreq/scaling_governor:performance
/sys/devices/system/cpu/cpu3/cpufreq/scaling_max_freq:1700000
/sys/devices/system/cpu/cpu3/cpufreq/scaling_min_freq:768000
/sys/devices/system/cpu/cpu3/cpufreq/scaling_setspeed:<unsupported>
