I am searching for a free software to create macros for games on Linux, that could work on any keyboard with a GUI.
I want it to do successive keystrokes and tweak the delay between each key.
You must install the software Autokey, you can type this in the terminal:
sudo apt-get install autokey-gtk
Open it and click on New then Script and name it (you can also create a folder with the name of your game).
Keyboard
There is two important lines, here is the code for pressing the key "x":
keyboard.send_keys("x")
And here is how to add a delay, 1/10 of a second (try lower values until the game doesn't allow it, also keep in mind than an high ping can make some keys doesn't input if the delay is too low):
time.sleep(0.1)
Then repeat the code by adding a delay between each keys, for the last key you don't need to add a delay after it.
To hold a key type that, for example to hold then release Shift and typing x in between:
keyboard.press_key("<shift>")
keyboard.release_key("<shift>")
Mouse
To click use this two commands:
mouse.click_relative_self(x, y, button)
mouse.click_absolute(x, y, button)
The first command is relative (to click near the mouse's current location) the second is absolute (from the entire screen). The button takes 3 arguments:
1: left click
2: middle click
3: right click
This script work best if you add a minimum of 0.1 second of sleep. Here an example to click at the center of the screen:
time.sleep(0.1)
mouse.click_absolute(1920/2, 1080/2, 1)
Comment
You can add a comment with "#":
keyboard.send_keys("x") # use a potion
Once your script is finished you can bind it to a key, bellow your script you will see script settings, at the line Hotkey click on Set and define a key. I recommend you to use the key F# to attach it or the key. You can test if your macro is working by opening a text editor like gedit.
For Dota it is better to use the in game queue feature, for example to use 3 items and one spell:
keyboard.send_keys("s") time.sleep(0.01) keyboard.press_key("") keyboard.send_keys("zxcq") # edit this line keyboard.release_key("")
