I used to use Ubuntu 14.04 trusty for our NAT server (build on Google Cloud Platform), but recently I tried to use the Ubuntu 16.04 xenial.
I configured perfectly same as I've done in 14.04, but it DOESN'T WORK as NAT server. The only difference is the versions of the OS and libraries.
The configuration is quite simple, which is described in Google's documentation:
  1. Allow IP forwarding sudo sysctl -w net.ipv4.ip_forward=1 and
  2. Configure the iptables sudo iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE
https://cloud.google.com/compute/docs/networking#natgateway
That's it. In Ubuntu 14.04, it worked. In Ubuntu 16.04, it didn't.
Can someone help me to configure it correctly? I have no idea what I'm missing nor what point I should check.
Thanks in advance!
Here're the additional info
In Ubuntu 14.04
$ cat /etc/lsb-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=14.04
DISTRIB_CODENAME=trusty
DISTRIB_DESCRIPTION="Ubuntu 14.04.5 LTS"
$ sudo dpkg -l iptables
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name             Version       Architecture  Description
ii  iptables         1.4.21-1ubunt amd64         administration tools for packet filte
$ sudo iptables -v -x -n -L
Chain INPUT (policy ACCEPT 5898 packets, 944634 bytes)
    pkts      bytes target     prot opt in     out     source               destination
    5898   944634 sshguard   all  --  *      *       0.0.0.0/0            0.0.0.0/0
Chain FORWARD (policy ACCEPT 40 packets, 3444 bytes)
Chain OUTPUT (policy ACCEPT 5658 packets, 526971 bytes)
Chain sshguard (1 references)
$ sudo iptables -t nat -v -x -n -L
Chain PREROUTING (policy ACCEPT 18 packets, 3471 bytes)
Chain INPUT (policy ACCEPT 14 packets, 3231 bytes)
Chain OUTPUT (policy ACCEPT 797 packets, 48528 bytes)
Chain POSTROUTING (policy ACCEPT 0 packets, 0 bytes)
     801    48768 MASQUERADE  all  --  *      eth0    0.0.0.0/0            0.0.0.0/0
$ ifconfig
eth0      Link encap:Ethernet  HWaddr 12:34:56:78:90:ab
          inet addr:10.146.0.3  Bcast:10.146.0.3  Mask:255.255.255.255
          inet6 addr: fe80::4001:aff:fe92:3/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1460  Metric:1
          RX packets:6379 errors:0 dropped:0 overruns:0 frame:0
          TX packets:6099 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:1080290 (1.0 MB)  TX bytes:644140 (644.1 KB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
$ sudo sysctl net.ipv4.ip_forward
net.ipv4.ip_forward = 1
In Ubuntu 16.04
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=16.04
DISTRIB_CODENAME=xenial
DISTRIB_DESCRIPTION="Ubuntu 16.04.2 LTS"
ii  iptables         1.6.0-2ubuntu amd64         administration tools for packet filte
$ sudo iptables -L -v -x -n
Chain INPUT (policy ACCEPT 474 packets, 44440 bytes)
Chain FORWARD (policy ACCEPT 0 packets, 0 bytes)
      16      960 ACCEPT     all  --  *      ens4    0.0.0.0/0            0.0.0.0/0
       0        0 ACCEPT     all  --  ens4   *       0.0.0.0/0            0.0.0.0/0            state RELATED,ESTABLISHED
Chain OUTPUT (policy ACCEPT 355 packets, 38412 bytes)
Chain PREROUTING (policy ACCEPT 9 packets, 3013 bytes)
Chain INPUT (policy ACCEPT 6 packets, 2833 bytes)
Chain OUTPUT (policy ACCEPT 756 packets, 46153 bytes)
Chain POSTROUTING (policy ACCEPT 759 packets, 46333 bytes)
       0        0 MASQUERADE  all  --  *      ens4    0.0.0.0/0            0.0.0.0/0
$ sudo ifconfig
ens4      Link encap:Ethernet  HWaddr 12:34:56:78:90:ab
          inet addr:10.146.0.4  Bcast:10.146.0.4  Mask:255.255.255.255
          inet6 addr: fe80::4001:aff:fe92:4/64 Scope:Link
          RX packets:6274 errors:0 dropped:0 overruns:0 frame:0
          TX packets:6064 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:1043141 (1.0 MB)  TX bytes:641746 (641.7 KB)
I believe this has to do with a systemd-networkd change. I was trying to accomplish something similar recently on Ubuntu 16.04, and stumbled across a webpage explaining that forwarding has to be enabled on the interface itself. I am unable to find this webpage at the moment, and I don't know when this was changed.
So this will enable forwarding, but in addition to this, it has to be enabled on the interface
To see if forwarding is enabled or not, run this:
sysctl -a | grep forwarding
To enable forwarding on eth0, run this:
sudo sysctl net.ipv4.conf.eth0.forwarding=1
I believe I read that enabling forwarding on an interface will set net.ipv4.ip_forward to 1, so the first step might not be necessary. If this is the case, disabling forwarding again on the interface will not revert net.ipv4.ip_forward back to 0. At least that's how I remember it.
Tobias
  • 1,678
Make sure you have set set the firewall to allow forwarding of traffic. It's possible that switching to Ubuntu 16 that the firewall is preconfigured to an implicit deny policy for packet forwarding
sudo iptables -A FORWARD -o eth0 -j ACCEPT
sudo iptables -A FORWARD -m state \
--state ESTABLISHED,RELATED -i eth0 -j ACCEPT
Also make sure that you have added your NAT rule to run after reboot. Add the same rule to /etc/rc.local
Gansheim
  • 871
