When I wake my laptop up after being suspended for a little while, the WiFi signal gets replaced by up and down arrows. The connection still works, but is rather annoying nonetheless. Restarting the Network Manager works, but is only a temporary fix.
I read somewhere that it might be because the connection is getting renamed, thus causing it to think I'm connected via Ethernet instead of WiFi?
How can I fix this?
Edit: I've noticed that this also happens on occasion after turning WiFi on/off.
Mixx
  • 673
Automatic Method
Using sudo powers create the file /lib/systemd/system-sleep/iwlwifi-reset containing:
#!/bin/sh
DESC: Resets Intel WiFi after a long suspend.
DATE: Apr 1, 2017. Modified April 8, 2017.
NOTE: Per AU comment restart network.
MYNAME=$0
restart_wifi() { /usr/bin/logger $MYNAME 'restart_wifi BEGIN'
/sbin/modprobe -v -r iwldvm # This removes iwlwifi too
/sbin/modprobe -v iwlwifi # This starts iwldvm too
systemctl restart NetworkManager.service
/usr/bin/logger $MYNAME 'restart_wifi END'
/usr/bin/logger $MYNAME 'case=[' ${1}' ]' case "${1}/${2}" in hibernate|suspend|pre) ;; resume|thaw|post) restart_wifi;; esac
Mark the script as executable using:
sudo chmod a+x /lib/systemd/system-sleep/iwlwifi-reset
To check execution of the script after waking up from suspend use:
cat /var/log/syslog | grep iwlwifi
Don't get too excited if it seems to work during testing because there are times when this script works with a short suspend but doesn't work after a long suspend.
If this doesn't work, before trying the Manual Method in the next section, place the command sleep 5 before the line restart_wifi;;.
Manual Method
If the automatic method isn't working using sudo powers create the script /usr/local/bin/iwlwifi-reset containing:
#!/bin/sh
DESC: Manually reset Intel WiFi.
NOTE: Must call using SUDO POWERS.
MYNAME=$0
modprobe -r iwldvm # This removes iwlwifi too
modprobe iwlwifi # This starts iwldvm too
systemctl restart NetworkManager.service /usr/bin/logger $MYNAME 'restart_wifi END'
sudo chmod a+x /usr/local/bin/iwlwifi-reset
As described in the last section you can check /var/log/syslog for messages when this script is run but you will see any error messages in your terminal anyway.
To call this script use:
sudo iwlwifi-reset
You don't need to specify the directory because /usr/local/bin is in the terminal's command search path.
Edit April 8, 2017 As per OP comment and this How-To, revisions to script were made. Instead of removing and reinserting kernel modules, restarting network services were used.
I had this issue also with my HP pavilon G6, which didn't really start until I got a new usb adaptor and plugged it in. After some searching I figured out that the wrong drivers were being used so I installed the correct drivers (Ralink) and it worked out. You didn't mention that you had a second adaptor but maybe checking to see what modprobe returns will help.
I got the idea from the last answer in this thread: Wifi doesn't work after suspend after 16.04 upgrade
