I need to replace my windows 10 system with Ubuntu. Not a dual boot as I do not need to keep Windows.
I do not want to lose my D: partition though. Windows is installed on the C: partition.
How can I do that?
Zanna
  • 72,312
Simply start the Ubuntu installer and when it asks where to install Ubuntu, be sure to choose "Something else". Then click the partition (named WINDOWS in all uppercase for sure) and delete it, then mount it to "/" as ext4 filesystem. Leave the other partition untouched (which is your D partition). The partitions will not be called C and D by the way. After installation the D drive should be accessible and most likely show up as a disk icon in the launcher.
As always I would say as good advice to backup your most important data from your D drive. It will make you feel a lot more comfortable during the installation and it is good to backup important data anyway ;-)
Good luck!
E.F. Nijboer
  • 1,351
Personally I would wait a short time and get the latest release 17.04. After loosing lots of data over the years, I would back up your stuff on your D drive, just in case. Then I would get a flash pen with a bootable version of Ubuntu and install it on there, Then I would install the latest version on the system.
Phil UK
  • 1,397
