Issue
  1. Ubuntu-14.04-LTS (Server) installed.
  2. It worked fine in the past year.
  3. Now, whenever I try to install a package file-system crashes and remounts as read-only.
Working on it
Trying to install a package (via dpkg -i or apt-get install) results in:
EXT4-fs error: mb_free_blocks:1433: group 3, block 130894:freeing already freed block (bit 32590); block bitmap corrupt.
Aborting journal on device vda1-8.
EXT4-fs error: ext4_journal_check_start:56: Detected aborted journal EXT4-fs: Remounting filesystem read-only EXT4-fs: Remounting filesystem read-only EXT4-fs error: ext4_mb_generate_buddy:756: group 3, 8181 clusters in bitmap, 8185 in gd; block bitmap corrupt.
fopen: Read-only file system debconf: DbDriver "config": could not write /var/cache/debconf/config.dat-new: Read-only file system dpkg: error processing package man-db (--install): subprocess installed post-installation script returned error exit status 1 dpkg: error: unable to create new file '/var/lib/dpkg/available-new': Read-only file system
The reason it mounts on read-only mode is because the default setting in /etc/fstab:
UUID=[MY-FS-UUID] / ext4 errors=remount-ro 0 1
In /var/log/syslog I can find:
EXT4-fs: INFO: recovery required on readonly filesystem EXT4-fs: write access will be enabled during recovery EXT4-fs: orphan cleanup on readonly fs EXT4-fs: 3 orphan inodes deleted EXT4-fs: recovery complete EXT4-fs: mounted filesystem with ordered data mode. Opts: (null) Adding 1046524k swap. Priority:-1 extents:1 across:1046524k FS EXT4-fs: re-mounted. Opts: errors=remount-ro
I tried using some of the solutions in the following:
  1. How to fix "sudo: unable to open ... Read-only file system"?
  2. Ubuntu boots in read-only filesystem after upgrade!
by doing so:
  • mount -o remount,rw -t ext4 MY_DISK /
mount: cannot remount block device MY_DISK read-write, is write-protected
  • blockdev -v --setrw MY_DISK
set read-write succeeded.
  • hdparm -r 0 MY_DISK
MY_DISK: setting readonly to 0 (off) readonly = 0 (off)
update 1
I can't access the disk. It seems that the system wrote to a place outside the disk and now it's corrupted. I made a QCOW image of the disk. I'm trying to run it as a VM, and analyze the corrupted image.
I installed libguestfs and I'm trying some analysis tools such as virt-cat, virt-rescue and guestfish.
My main goal now is trying to access and read the system logs.
update 2
In order to access the image, I connected the guest image as a device on the host x86 (credits: http://www.randomhacks.co.uk/how-to-recover-fsck-a-qcow2-file/, https://www.scaleway.com/docs/connect-a-block-device-manually/):
# fsck /dev/nbd0p1
/dev/nbd0p1: clean, 62744/983040 files, 447645/3931904 blocks
partition 1 is the os one. On partitions 2,5 I get errors from fsck - those are the extend and swap partitions, respectively.
# mount /dev/nbd0p1 /mnt/crpt
# cat /mnt/crpt/var/log/*
... currently searching through the logs ...
Help?
Any idea what might cause the system issue?
Alexis Wilke
  • 2,787
