I have a hardware which is Ublox EVK-M8T kit, with the GPS antenna.
I also install the gpsd and ntp in the Ubuntu system.
I check to make sure all are working probably, such as:
turn of daemon os:
sudo service gpsd stopRemove any sockets gpsd might have left behind:
sudo rm /var/run/gpsd.sockmake sure there is no instance of gpsd running:
sudo killall -9 gpsd ntpdfind the current USB devices connected to the RPI:
ls /dev/ttyACM0check that your device is emitting data, and save MNEA message to logfile:
gpsmon /dev/ttyACM0 -l logfileand also work with:
cgps -s xgpsreconfiguration file:
sudo service ntp reloadsee status overtime, show us all the clocks and what times are?
sudo ntpq -pcheck ntp status:
service ntp statuschange the server:
sudo vim /etc/ntp.confand:
ntpdate -d 192.168.1.231
Those are steps that I was trying to set up gpsd and ntpd, but I still do not understand, why do I have to do that?
How can I get an get Ubuntu system with ntpd receiving data from GPS through USB and set clock accuracy?
Thank you.
