12
I'm using WSL on Windows 10. I've installed gtkwave through the terminal, but I am unable to run it. My system gives me the following error:
Could not initialize GTK!  Is DISPLAY env var/xhost set?
I've tried installing xhost, but running xhost +LOCAL: only gives this error:
xhost:  unable to open display ":0"
How can I fix this and run GTK GUIs?
Zanna
  • 72,312
namila007
  • 241
WSL doesn't come with an X server by default, because Windows doesn't use an X server. Which would also be why xhost failed to do anything remotely useful.
In order to do something like this, you need to download an X server for Windows, and then configure that. For example, you can use the Xming project to run a display server. When launching Xming, you can use the -multiwindow option to make it so you don't have a virtual desktop. However, this may not be the case with other X servers present on Windows.
You can find a quick tutorial here for Xming specifically (really, it's just install + configure + export DISPLAY=:0) or here also for Xming. Alternatively you can use MobaXTerm (tutorial), which will achieve the same basic result.
In short, find an X server you like, and install it on Windows. After that, your WSL instance should be able to pick up on the fact that an X server is available, and you should be able to run GUI-based programs without much hassle.
Zanna
  • 72,312
Kaz Wolfe
  • 34,680
As of today, WSL should be able to run GTK software. If not, try updating your WSL from cmd/powershell.
wsl --update
willnode
  • 101
