I am seeing the below message during boot, preventing my system from running:
** 19 printk messages dropped **
[200.119021] nouveau <missing> fifo: sched_error 20[<missing>]
How can I fix this?
How can I fix this?
Upon boot, add nouveau.modeset=0 to the command-line arguments. Do this like so:
Ubuntu option and hit F3.linux line, after quiet splash.nouveau.modeset=0, and then hit F10.When you've booted into your computer, you're going to have to either install the NVIDIA drivers or update your boot config to not allow this error to happen further:
Type in the following command, exactly as it appears below:
sudo nano /etc/default/grub
You will be prompted with something that looks like [sudo] password for user:. Type in your password. You will not see any characters, but rest assured that your password is being typed. Press ENTER when done.
Go to this line:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
Edit it to look like:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash nouveau.modeset=0"
Press Ctrl+X, followed by the Y key, followed by the ENTER key to save your changes.
Run the exact command below to update your bootloader config:
sudo update-grub
Reboot to confirm that everything is working properly.
I use Lenovo Ideapad. I solved this issue via BIOS changes:
Configuration tab -> Graphic Device -> UMA Only.
