I am trying to install freetds-common, freetds-bin, unixodbc, and php5-sybase on Ubuntu 16.04.
When I run sudo apt-get install freetds-common freetds-bin unixodbc php5-sybase, I get the following errors:
Reading package lists... Done
Building dependency tree
E: Unable to locate package php5-sybase
How can I install this package?
Kaz Wolfe
  • 34,680
user670509
PHP5 is end of life now, and as such is no longer installable in Ubuntu 16.04 by default.
If you want to install PHP 5 packages, you're either going to have to downgrade to Ubuntu 16.04. Alternatively, if downgrading is not an option, you can try to use ondrej's PPA:
sudo add-apt-repository ppa:ondrej/php5-compat
sudo apt update
Afterwards, you should be able to install the packages you need.
However, it is important to note that PHP in general 5 is a security risk, and shouldn't be used if at all possible. If Bad Things happen, it's not our fault.
alesub
  • 103
Kaz Wolfe
  • 34,680
