I have just upgrade my desktop from ubuntu 14.04 LTS to 16.04 LTS. I have had the same situation as described here Kernel did not upgrade between 14.04 LTS to 16.04 LTS and Why is apt no longer updating the kernel? but none of the solutions have worked for me.
When doing sudo apt-get install linux I get
dev:~$sudo apt-get install linux
Reading package lists... Done
Building dependency tree
E: Unable to locate package linux
and when doing sudo apt install linux-generic I get
dev:~$sudo apt install linux-generic
linux-generic : Depends: linux-headers-generic (= 4.4.0.66.70) but 4.4.0.67.72 is to be installed
cat /etc/os-release
dev:~$ cat /etc/os-release
NAME="Ubuntu"
VERSION="16.04.2 LTS (Xenial Xerus)"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu 16.04.2 LTS"
VERSION_ID="16.04"
HOME_URL="http://www.ubuntu.com/"
SUPPORT_URL="http://help.ubuntu.com/"
BUG_REPORT_URL="http://bugs.launchpad.net/ubuntu/"
VERSION_CODENAME=xenial
UBUNTU_CODENAME=xenial
Installed images are (it is very long but at the end shows):
dpkg -l | grep linux-image
linux-image-extra-3.13.0-113-generic 3.13.0-113.160 amd64 Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
rc
linux-image-extra-4.4.0-67-generic 4.4.0-67.88 amd64 Linux kernel extra modules for version 4.4.0 on 64 bit x86 SMP
and also this:
dev:~$ uname -r
3.13.0-113-generic
I have not installed any kernel by myself but I understand that I have probably done something.
How can I resolve this situation?
EDIT
dev:~/temp$ apt-cache policy linux-headers-generic
linux-headers-generic:
Installed: 4.4.0.67.72
Candidate: 4.4.0.67.72
Version table:
*** 4.4.0.67.72 100
100 /var/lib/dpkg/status
4.4.0.66.70 500
500 http://se.archive.ubuntu.com/ubuntu xenial-updates/main amd64 Packages
500 http://security.ubuntu.com/ubuntu xenial-security/main amd64 Packages
4.4.0.21.22 500
500 http://se.archive.ubuntu.com/ubuntu xenial/main amd64 Packages
EDIT 2
The answer provided by fkraiem was the solution to my questions but I also upgrade the kernel with the help of the answer by user535733. Thanks guys!
