what that "windows" thing is doing here?
how safe is it?
when I double click on the js file (expecting gedit), it starts some process that I cannot find with ps... so,
what executable is that thing?
how/when that was installed? it is here from the beggining?
Any real use to have it installed? if not, I will uninstall it..
Windows Based Scripting Host (WSH) is a API to run Active Scripting languages like JScript or VBScript.
If the .js file you're trying to open is from a Windows system originally, it might actually be a JScript file (MS's dialect of JavaScript, or if new enough, a "JScript .NET" file) instead of a regular JavaScript file and have calls to ActiveX, etc.
You might want to take a look at / edit it in the Terminal (with nano for example) first, instead of trying to open it with gedit - just to see what it really contains.
Without knowing more about your system, it is hard to say what process opens when you doubleclick the file - there are several possibilities that can be used to handle .js files, like NodeJS or Rhino, etc. Neither of those are installed by default on Ubuntu, though.
DocWeird
  • 1,000
