I'm using GNU bash, version 4.3.46 on a Ubuntu machine. For some reason this while loop doesn't work as expected.
The menu should loop continuously until the user decides to quit the program, then there is some error checking prompting the user if they are sure, then the program ends.
Here's the code:
#!/bin/bash
menu_choice=0
quit_program="n"
while [[ $menu_choice -ne 3 && $quit_program != "y" ]]
do
    printf "1. Backup\n"
    printf "2. Display\n"
    printf "3. Exit\n\n"
    printf "Enter choice: \n"
    read menu_choice
    if [ $menu_choice -eq 3 ]
    then
        printf "Are you sure you want to quit? (y/n)\n"
        read quit_program
    fi
done
I think it might have to with global variables are declared at the beginning and I'm reading in a new value locally...
Zanna
  • 72,312
Mondo192
  • 81
The problem is in your while loop conditions. This line:
is saying "while menu_choice isn't 3 and quit_program isn't y, keep looping." The problem is that, if either of those conditions is no longer true, the while loop will end.
What you want is this:
while [[ $menu_choice -ne 3 || $quit_program != "y" ]]
using || instead of &&. This way, the while loop will continue to loop as long as either condition is true, instead of both.
TheWanderer
  • 19,525
  • 52
  • 65
This simpler script should work for you
#!/bin/bash
menu_choice=0
quit_program=false
while [ $quit_program == false ]
do
    read menu_choice
    then
        printf "Are you sure you want to quit? (y/n) "
        read ask
        if [ $ask == "y" ]
        then
            quit_program=true
        fi
    fi
done
printf "\nDone\n"
There's no need to keep checking the menu_choice, so that can be removed from the while loop check.
In my example above, I just set a boolean of quit_program which is checked in the loop. If the user chooses option 3, and then says "y" to the confirmation, then the boolean is set to true to kill the loop.
You can also go even further without checking a boolean with this:
#!/bin/bash
menu_choice=0
while true
do
    read menu_choice
    then
        read ask
        if [ $ask == "y" ]; then break; fi
    fi
done
printf "\nDone\n"
This second example accomplishes the same thing, but the while loop just runs without checking the boolean from before. The loop is broken with the break command instead.
Delorean
  • 11,563
