I usually connect to a remote machine through a firewall with:
ssh -xv farshidhss@ras.cse.ust.hk
And then:
ssh -xv luca@10.89.100.72
Notice that remote is actually an IP address. I've seen this question and tried to write my ~/.ssh/config file as:
Host ras
Hostname ras.cse.ust.hk
User farshidhss
Host farshid
ProxyCommand ssh -q ras nc -q0 10.89.100.72 22
And then tried ssh -xv luca@farshid, but it stucks at the last line of:
luca@jarvis:~$ ssh -xv luca@farshid
OpenSSH_7.2p2 Ubuntu-4ubuntu2.1, OpenSSL 1.0.2g  1 Mar 2016
debug1: Reading configuration data /home/luca/.ssh/config
debug1: /home/luca/.ssh/config line 5: Applying options for farshid
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 19: Applying options for *
debug1: Executing proxy command: exec ssh -q ras nc -q0 10.89.100.72 22
debug1: permanently_drop_suid: 1000
debug1: identity file /home/luca/.ssh/id_rsa type 1
debug1: key_load_public: No such file or directory
debug1: identity file /home/luca/.ssh/id_rsa-cert type -1
debug1: identity file /home/luca/.ssh/id_dsa type -1
debug1: identity file /home/luca/.ssh/id_dsa-cert type -1
debug1: identity file /home/luca/.ssh/id_ecdsa type -1
debug1: identity file /home/luca/.ssh/id_ecdsa-cert type -1
debug1: identity file /home/luca/.ssh/id_ed25519 type -1
debug1: identity file /home/luca/.ssh/id_ed25519-cert type -1
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_7.2p2 Ubuntu-4ubuntu2.1
I checked that the ports are correct and tried also ProxyCommand ssh -W 10.89.100.72:22 farshid but without success and netcat is installed on ras.cse.ust.hk (which nc returned /bin/nc).
Updated ~/ssh/config:
Host ras
User farshidhss
Host farshid
User luca
ProxyCommand ssh -o 'ForwardAgent yes' farshidhss@ras.cse.ust.hk 'ssh-add && nc %h %p'
Tried to connect with ssh -xv farshid but having same output of before and stucked there
user6321
  • 175
