apt-get -f install fails
apt-get upgrade Fails
I am missing many packages required for my companies software
after installing our software several issues started popping up
these are missing dependencies/packages
there are probably others however these are the ones that come up when I search for packages missing dependencies
libgnutlsxx27:amd64
libatomic1:amd64
cpp-4.8
g++-4.8
libexpat1-dev:amd64
libxext-dev:amd64
libstdc++-4.8-dev:amd64
libaprutil1-dev
libquadmath0:amd64
libcairo2-dev
libtsan0:amd64
gcc-4.8
libfontconfig1-dev
libgcc-4.8-dev:amd64
libidn11-dev
php5-gd
libldap2-dev:amd64
php5-curl
libcairomm-1.0-dev:amd64
g++
libtasn1-6-dev
libasan0:amd64
libgfortran3:amd64
libpython2.7-dev:amd64
libpng12-dev
cpp
libcurl4-gnutls-dev:amd64
build-essential
gcc
libpython-dev:amd64
comerr-dev
libboost1.54-dev
libhdf5-7:amd64
libc6:amd64
libc6:i386
libsm6:amd64
gvfs-daemons
libboost-date-time1.54-dev:amd64
libxxf86vm1:amd64
protobuf-c-compiler
libboost-mpi1.54.0
libgnutls-dev
libv8-3.14.5
libboost-program-options1.54-dev:amd64
php5-readline
postgresql-contrib-9.3
libpixman-1-0:amd64
libcolord1:amd64
libpcre3-dev:amd64
make
libgmp10:amd64
When running the init.d command the system stated that the init.d does not exist
I checked the folder and its there
How can I fix it?
sudo apt-get -f install -y Reading package lists... Building dependency tree... Reading state information... Correcting dependencies... Done The following extra packages will be installed: comerr-dev cpp cpp-4.8 dpkg-dev gcc gcc-4.8 krb5-multidev libaprutil1-dev libasan0 libatomic1 libc6 libcurl3-gnutls libcurl4-gnutls-dev libdpkg-perl libexpat1-dev libfreetype6-dev libgcc-4.8-dev libgl1-mesa-glx libglapi-mesa libgmp10 libgnutls-dev libgnutlsxx27 libgomp1 libgssapi-krb5-2 libgssrpc4 libidn11-dev libitm1 libk5crypto3 libkadm5clnt-mit9 libkadm5srv-mit9 libkrb5-3 libkrb5-dev libkrb5support0 libldap2-dev libpci-dev libpcre3-dev libpcrecpp0 libpixman-1-0 libpixman-1-dev libpng12-dev libpq-dev libpq5 libquadmath0 libsm6 libsqlite3-dev libtasn1-6-dev libtsan0 libxxf86vm1 make openjdk-7-jre openjdk-7-jre-headless postgresql-9.3 postgresql-contrib-9.3 Suggested packages: doc-base cpp-doc gcc-4.8-locales debian-keyring gcc-multilib automake1.9 flex bison gdb gcc-doc gcc-4.8-multilib gcc-4.8-doc libgcc1-dbg libgomp1-dbg libitm1-dbg libatomic1-dbg libasan0-dbg libtsan0-dbg libquadmath0-dbg krb5-doc glibc-doc libcurl4-doc libcurl3-dbg gnutls26-doc gnutls-bin krb5-user postgresql-doc-9.3 sqlite3-doc make-doc icedtea-7-jre-jamvm libnss-mdns sun-java6-fonts fonts-ipafont-gothic fonts-ipafont-mincho ttf-wqy-microhei ttf-wqy-zenhei ttf-indic-fonts-core ttf-telugu-fonts ttf-oriya-fonts ttf-kannada-fonts ttf-bengali-fonts oidentd ident-server locales-all libdbd-pg-perl Recommended packages: build-essential The following NEW packages will be installed: comerr-dev cpp cpp-4.8 gcc gcc-4.8 libaprutil1-dev libasan0 libatomic1 libcurl4-gnutls-dev libexpat1-dev libgmp10 libgnutls-dev libgnutlsxx27 libldap2-dev libpcre3-dev libpixman-1-0 libpng12-dev libquadmath0 libsm6 libtasn1-6-dev libtsan0 libxxf86vm1 make postgresql-contrib-9.3 The following packages will be upgraded: dpkg-dev krb5-multidev libc6 libcurl3-gnutls libdpkg-perl libfreetype6-dev libgcc-4.8-dev libgl1-mesa-glx libglapi-mesa libgomp1 libgssapi-krb5-2 libgssrpc4 libidn11-dev libitm1 libk5crypto3 libkadm5clnt-mit9 libkadm5srv-mit9 libkrb5-3 libkrb5-dev libkrb5support0 libpci-dev libpcrecpp0 libpixman-1-dev libpq-dev libpq5 libsqlite3-dev openjdk-7-jre openjdk-7-jre-headless postgresql-9.3 Preconfiguring packages ... 29 upgraded, 24 newly installed, 0 to remove and 105 not upgraded. 337 not fully installed or removed. Need to get 0 B/65.8 MB of archives. After this operation, 45.9 MB of additional disk space will be used. (Reading database ... 82106 files and directories currently installed.) Preparing to unpack .../libc6_2.19-0ubuntu6.11_amd64.deb ... Unpacking libc6:amd64 (2.19-0ubuntu6.11) over (2.19-0ubuntu6.5) ... Extracting templates from packages: 100% dpkg: error processing archive /var/cache/apt/archives/libc6_2.19-0ubuntu6.11_amd64.deb (--unpack): trying to overwrite shared '/usr/share/doc/libc6/changelog.Debian.gz', which is different from other instances of package libc6:amd64 dpkg-deb: error: subprocess paste was killed by signal (Broken pipe) Errors were encountered while processing: /var/cache/apt/archives/libc6_2.19-0ubuntu6.11_amd64.deb E: Sub-process /usr/bin/dpkg returned an error code (1) sudo apt -f dist-upgrade Reading package lists... Done Building dependency tree Reading state information... Done Correcting dependencies... Done Calculating upgrade... Done The following NEW packages will be installed: comerr-dev cpp cpp-4.8 gcc gcc-4.8 libaprutil1-dev libasan0 libatomic1 libcurl4-gnutls-dev libexpat1-dev libgmp10 libgnutls-dev libgnutlsxx27 libldap2-dev libpcre3-dev libpixman-1-0 libpng12-dev libquadmath0 libsm6 libtasn1-6-dev libtsan0 libxxf86vm1 linux-headers-4.4.0-66 linux-headers-4.4.0-66-generic linux-image-4.4.0-66-generic linux-image-extra-4.4.0-66-generic linux-signed-image-4.4.0-66-generic make postgresql-contrib-9.3 The following packages will be upgraded: apache2 apache2-bin apache2-data apache2-dev binutils dbus-x11 dh-apparmor dpkg-dev fontconfig fontconfig-config git git-core git-man icu-devtools krb5-multidev libapache2-mod-php5 libavahi-client3 libavahi-common-data libavahi-common3 libavahi-glib1 libbatik-java libc-ares2 libc6 libcups2 libcurl3-gnutls libdpkg-perl libdrm-intel1 libdrm-nouveau2 libdrm-radeon1 libfontconfig1 libfreetype6-dev libfreexl1 libgcc-4.8-dev libgcrypt11 libgcrypt11-dev libgdk-pixbuf2.0-0 libgdk-pixbuf2.0-common libgl1-mesa-dri libgl1-mesa-glx libglapi-mesa libgomp1 libgraphite2-3 libgssapi-krb5-2 libgssrpc4 libgtk2.0-0 libgtk2.0-bin libgtk2.0-common libharfbuzz0b libibverbs-dev libibverbs1 libicu-dev libicu52 libidn11-dev libitm1 libjasper-dev libjasper1 libk5crypto3 libkadm5clnt-mit9 libkadm5srv-mit9 libkdb5-7 libkrb5-3 libkrb5-dev libkrb5support0 liblcms2-2 liblwgeom-2.1.2 libmysqlclient-dev libmysqlclient18 libnspr4 libnss3 libnss3-nssdb libpci-dev libpcrecpp0 libpixman-1-dev libpoppler44 libpostgis-java libpq-dev libpq5 libpulse0 libsndfile1 libsqlite3-dev libssl-dev libssl-doc libssl1.0.0 libsvn1 libtdb1 libtiff4-dev libtiff5 libtiff5-dev libtiffxx5 libuuid1 libxerces-c-dev libxerces-c3.1 libxfixes3 libxfont1 libxi6 libxml2 libxml2-dev libxrandr2 libxrender-dev libxrender1 linux-headers-generic-lts-xenial linux-libc-dev linux-signed-generic-lts-xenial linux-signed-image-generic-lts-xenial munin-common munin-doc munin-node munin-plugins-core munin-plugins-extra mysql-common openjdk-7-jre openjdk-7-jre-headless php-pear php5 php5-cli php5-common php5-pgsql postgresql postgresql-9.3 postgresql-9.3-postgis-scripts postgresql-client-9.3 postgresql-client-common postgresql-common postgresql-contrib postgresql-server-dev-9.3 subversion tzdata tzdata-java unzip uuid-dev wget x11-common x11proto-core-dev xtrans-dev 134 upgraded, 29 newly installed, 0 to remove and 0 not upgraded. 337 not fully installed or removed. Need to get 67.2 MB/189 MB of archives. After this operation, 348 MB of additional disk space will be used. Do you want to continue? [Y/n] y Fetched 67.2 MB in 1min 3s (1,053 kB/s) Extracting templates from packages: 100% Preconfiguring packages ... (Reading database ... 82106 files and directories currently installed.) Preparing to unpack .../libc6_2.19-0ubuntu6.11_amd64.deb ... Unpacking libc6:amd64 (2.19-0ubuntu6.11) over (2.19-0ubuntu6.5) ... dpkg: error processing archive /var/cache/apt/archives/libc6_2.19-0ubuntu6.11_amd64.deb (--unpack): trying to overwrite shared '/usr/share/doc/libc6/changelog.Debian.gz', which is different from other instances of package libc6:amd64 dpkg-deb: error: subprocess paste was killed by signal (Broken pipe) Errors were encountered while processing: /var/cache/apt/archives/libc6_2.19-0ubuntu6.11_amd64.deb E: Sub-process /usr/bin/dpkg returned an error code (1)
