I'm decently new to using a Raspberry Pi and I'm trying to set up a simple GUI application to launch from my Pi. I'm using a Raspberry Pi3, with Python 3.4.3 installed.
When I type python:
~$ python
Python 3.4.3 |Continuum Analytics, Inc.| (default, Aug 21 2015, 00:53:08)
[GCC 4.6.3] on linux
Type "help", "copyright", "credits" or "license" for more information.
When I try to import tkinter:
>>> import tkinter
Traceback (most recent call last):
    File "<stdin>", line 1, in <module>
    File "/home/pi/miniconda3/lib/python3.4/tkinter/__init__.py", line 38, in <module>
        import _tkinter # If this fails your Python may not be configured for Tk
ImportError: No module named '_tkinter'
So, I can see that the error is coming from miniconda3. The only reason I had it installed was to use PyQt5, but I was getting a similar error when I tried to use that, so I switched over to Tkinter because there were more examples of using it with a pi online.
I have run the following commands to try to install Tkinter:
sudo apt-get install tk-dev
sudo apt-get install tk8.6-dev
sudo apt-get install python-imaging-tk
sudo apt-get install python-tk
sudo apt-get install python3-tk
How can I fix this? I have read in some places to make python again, but no one says how to do that.
Thanks guys!
Delorean
  • 11,563
J. Schach
Install the Tkinter package for writing Tk applications with Python 3.x. In all currently supported versions of Ubuntu, open the terminal and type:
sudo apt install python3-tk # for Python 2.x install python-tk
Then run /usr/bin/python3 to start the default Python 3 that comes with Ubuntu and import tkinter will work.
karel
  • 122,292
  • 133
  • 301
  • 332
  • It seems that you are launching mini-conda python not python that comes with raspberry-pi distribution. You could check the output of:
    which python
    Expected output: /usr/local/bin/python or mini-conda custom installation path (if it was added before.)
  • Test also if Tk works when launching python using absolute path:
    /usr/bin/python
  • To complete my answer, if you like to use miniconda python, use its own installation method:
    conda install packagename
    Reference: Miniconda homepage, :) I'm not aware of the exact package name of tkinter.
user.dz
  • 49,176
