I was using facebook messenger, and When I finished my call, the web cam stilled working.I have an integrated camera in my laptop HP 630. Is there a way to turn it off ? Thanks.
Thank you guys, the problem is gone.
- I used the command : lsof | grep video0 to find the software using my webcam. It was FireFox.
- I just restarted FireFox, and then the webcam turned off.
- 341
If the webcam behaves weirdly, not automatically turning off for example, you can:
To disable the webcam run:
sudo modprobe -r uvcvideo
It removes the module from the Linux Kernel.
To re-enable the webcam you can either restart or run:
sudo modprobe -a uvcvideo
Reinserts the module.
- 3,538
- 5
- 24
- 40
sudo rmmod -f uvcvideo(to kill laptop camera)sudo modprobe -r uvcvideo(to restart the video module)sudo modprobe uvcvideo(to restart the laptop camera)sudo modprobe -a uvcvideo(can be used while skipping steps 2&3 to restart the camera directly)
- 20,055
- 57
- 82
- 84
- 31
- 1
If you know the application name, you can use the following to get the process ID:
ps -fA | grep application_name
Output: process_name PID PPID .....
Then you can kill the process using:
kill -9 PID
I found an easy solution... It happens if you have configured your sound input for the webcam mic. Change it to another and the light turns off.
