Ok. I really need help. I messed up Ubuntu 16.04 LTS so I decided that upgrading to 16.10 will fix the broken packages. It did, but now I can't use the internet. At all. I have a Lenovo Ideapad with Realtek ethernet adapter. It says that the ethernet is "not managed". I tried modifying the managed=false to managed=true in /etc/NetworkManager/NetworkManager.conf but that didn't work. Can anybody help me?
Asked
Active
Viewed 1,368 times
The_Encoder
- 15
- 1
- 9
For me the following commands solved the issue and LAN connection was immediately detected.
sudo touch /etc/NetworkManager/conf.d/10-globally-managed-devices.conf
sudo service network-manager restart
if the above doesn't work try the following
sudo sh -c "echo 'net.ipv6.conf.all.disable_ipv6 = 1' >> /etc/sysctl.conf"
sudo sh -c "echo 'net.ipv6.conf.default.disable_ipv6 = 1' >> /etc/sysctl.conf"
sudo sh -c "echo 'net.ipv6.conf.lo.disable_ipv6 = 1' >> /etc/sysctl.conf"
sudo sysctl -p
sudo sed -i 's/false/true/g' /etc/NetworkManager/NetworkManager.conf
sudo reboot -i NOW
Good luck!
Elangovan Manickam
- 121
- 1
I solved the problem. Unfortunately, I needed to reinstall Ubuntu 16.10. And now I need to reinstall all the programs. Because Ubuntu live-USB doesn't have "Repair Current Install", which I consider a shame, since may other distros have that.
The_Encoder
- 15
- 1
- 9
