I have two questions
  1. I installed Ubuntu 11.10 inside of Windows 7 on dual-boot using the Wubi installer. I believe I used the 2nd option of 'installing inside windows' with 'reduced disk performance'. Just wondering what the best way is to remove Windows and have those partitions available for use by Oneiric Ocelot.
  2. Is it possible to change the boot menu options to have Ubuntu first. If so, how do I do this.
I'm open to good ideas.
htorque
  • 66,086
If you are ready to remove windows, probably the easiest thing to do would be to back up your data and do a fresh, standard install overwriting all your partitions.
Your other option would be to migrate your wubi install outside of windows and then delete windows.
migrating wubi has been discussed here : How to migrate from Wubi to a regular installation?
Panther
  • 104,528
