The configuration files are managed by ucf and you can set system wide configuration via editing /etc/ucf.conf For reference, here's an unedited example from one of my Ubuntu 16.04 installations:
# This file is a bourne shell snippet, and is sourced by the
# ucf script for configuration.
# Debugging information: The default value is 0 (no debugging
# information is printed). To change the default behavior, uncomment
# the following line and set the value to 1.
# DEBUG=0
# Verbosity: The default value is 0 (quiet). To change the default
# behavior, uncomment the following line and set the value to 1.
# VERBOSE=0
# The src directory. This is the directory where the historical
# md5sums for a file are looked for. Specifically, the historical
# md5sums are looked for in the subdirectory ${filename}.md5sum.d/
# conf_source_dir=/some/path/
# Force the installed file to be retained. The default is have this
# variable unset, which makes the script ask in case of doubt. To
# change the default behavior, uncomment the following line and set
# the value to YES
# conf_force_conffold=YES
# Force the installed file to be overridden. The default is have this
# the value to YES
# conf_force_conffnew=YES
# Please note that only one of conf_force_conffold and
# conf_force_conffnew should be set.
If you wish to keep your currently installed versions of all configuration files you can simply edit this file and remove the comment marker # from the line that contains # conf_force_conffold=YES
For more precise handling, it's worth mentioning that you can control specific configuration files with ucf. That however is beyond the scope of this answer.
Source:
http://manpages.ubuntu.com/manpages/xenial/man5/ucf.conf.5.html
