This page example how to use minicom
Install minicom
sudo apt-get install minicom
Display Detected System’s Serial Support
dmesg | grep tty
Output will be something like:
[ 37.531286] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 37.531841] 00:0b: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 37.532138] 0000:04:00.3: ttyS1 at I/O 0x1020 (irq = 18) is a 16550A
setserial command
setserial is a program designed to set and/or report the configuration information associated with a serial port. This information includes what I/O port and IRQ a particular serial port is using, and whether or not the break key should be interpreted as the Secure Attention Key, and so on. Just type the following command:
setserial -g /dev/ttyS[0123]
Output:
/dev/ttyS0, UART: 16550A, Port: 0x03f8, IRQ: 4
/dev/ttyS1, UART: 16550A, Port: 0x1020, IRQ: 18
/dev/ttyS2, UART: unknown, Port: 0x03e8, IRQ: 4
/dev/ttyS3, UART: unknown, Port: 0x02e8, IRQ: 3
setserial with -g option help to find out what physical serial ports your Linux box has.
Setup minicom
The -s option use to setup minicom. Type the following command at shell prompt:
minicom -s
Start minicom
minicom
Configure serial port
You need to configure serial port. Use up and down arrows to select menus. Press down and select Serial port setup:
minicom in action
You need to connect your serial device usingcable. Once connected power on device and type minicom command without -s option:
minicom -c on
