I am trying to fix hibernate on my desktop. I am running a x99 motherboard, Ubuntu 16.04, kernel 4.8.0-41-generic, and nvidia-370.
I can successfully hibernate by manually setting /sys/power/disk to shutdown instead of the default platform and manually telling the kernel to hibernate. I learned how to do this from https://help.ubuntu.com/community/PowerManagement/Hibernate.
sudo -s echo shutdown > /sys/power/disk echo disk > /sys/power/state
This works nearly perfectly. There are some slight graphical issues with the task bar that go away when you click on it. Also, my nvidia settings get slightly reset. I can live with that. The other versions of nvidia driver I have tried crash hard.
When the value is platform my PC will not shut all the way down. I have to hard power off. However, when I restart the state is resumed correctly. Only when I manually force it hibernate and manual set the value shutdown does my PC shut off and state is resumed.
Since this worked, tried to make my /sys/power/disk default to shutdown instead of platform. I followed the advice of https://askubuntu.com/a/837334/154184 but the value seems stay platform.
jophde@pyre:~$ sudo cat /etc/pm/config.d/hibernate_mode HIBERNATE_MODE="shutdown"
I believe my file permissions are correct since there are the same as the defaults file. jophde@pyre:~$ sudo ls -lah /etc/pm/config.d/hibernate_mode -rw-r--r-- 1 root root 26 Mar 22 02:32 /etc/pm/config.d/hibernate_mode jophde@pyre:~$ sudo ls -lah /usr/lib/pm-utils/defaults -rw-r--r-- 1 root root 2.0K Mar 22 01:52 /usr/lib/pm-utils/defaults
The code that gets run when you run sudo pm-hibernate and reads in these values is /usr/lib/pm-utils/pm-functions. The part that sets the values from the defaults and user configs seems a bit hacky so maybe there is a bug there?
for cfg in "${PM_UTILS_ETCDIR}"/config.d/*[!~] \ "${PM_UTILS_ETCDIR}/${STASHNAME}.config.d"/*[!~]; do [ -f "$cfg" ] || continue # Ugly, I know. The goal here is to allow multiple files in # /etc/pm/config.d declare these variables and have those # declarations add together instead of the last one overwriting # all the others. [ "$SUSPEND_MODULES" ] && REAL_SUSPEND_MODULES="$SUSPEND_MODULES" [ "$HOOK_BLACKLIST" ] && REAL_HOOK_BLACKLIST="$HOOK_BLACKLIST" [ "$ADD_PARAMETERS" ] && REAL_ADD_PARAMETERS="$ADD_PARAMETERS" [ "$DROP_PARAMETERS" ] && REAL_DROP_PARAMETERS="$DROP_PARAMETERS" set -a . "${cfg}" SUSPEND_MODULES="$REAL_SUSPEND_MODULES $SUSPEND_MODULES" HOOK_BLACKLIST="$REAL_HOOK_BLACKLIST $HOOK_BLACKLIST" ADD_PARAMETERS="$REAL_ADD_PARAMETERS $ADD_PARAMETERS" DROP_PARAMETERS="$REAL_DROP_PARAMETERS $DROP_PARAMETERS" set +a done I don't have any other configs in /etc/pm/config.d/ and I did not modify /usr/lib/pm-utils/defaults.
How do I get HIBERNATE_MODE="shutdown" to work with Ubuntu Hibernate menu item and pm-hibernate?
https://linux.die.net/man/8/pm-hibernate
jophde
  • 111
