I am trying to configure the i915 driver on my XPS 13 (9360) running Ubuntu 16.04 for better battery runtime.
I have created a kernel config file with this name:
/etc/modprobe.d/i915.conf
Content of the file:
options i915 modeset=1 enable_rc6=1 enable_fbc=1 enable_guc_loading=1 enable_guc_submission=1 enable_huc=1 enable_psr=1 disable_power_well=0
I have restarted the machine and checked the driver parameters with this:
systool -v -m i915
This doesn't list my options in the "Parameters" section.
Seems like my options are not set to the driver at all (only the "enable_hangcheck" option with its "Y" default value).
What am I doing wrong?
sola
  • 473
The solution was to regenerate the boot images with update-initramfs (thanks Denis).
For all kernels (if you have more than one installed)
update-initramfs -u -k all
For the currently used kernel (if you don't want to touch the others)
update-initramfs -u
After this, the options were set because I saw a boot-time error about "enable_huc" parameter being invalid (dmesg). However, systool still doesn't show the options.
sola
  • 473
I created /usr/share/X11/xorg.conf.d/20-intel.conf, see also
man intel
#/usr/share/X11/xorg.conf.d/20-intel.conf
Section "Device"
   Identifier  "Intel Graphics"
   Driver      "intel"
   Option      "AccelMethod"  "uxa"
EndSection
And now I have a decent background.
