I want to run vncserver on startup How I can do it in startup file directly or create a custom Command via alias if possible
Asked
Active
Viewed 1,078 times
First, install the TightVNC server
sudo apt-get install tightvncserver.Set up the VNC server for the user you wish to log in as. When you run "vncserver" for the first time, it will ask you to set a password. only allow SSH tunnelled or VPN connections. To launch programs or a session when your VNC session starts, modify
~/.vnc/xstartup. Here is an example.#!/bin/sh xrdb $HOME/.Xresources xsetroot -solid black /opt/azureus/azureus & k3b & icewm-session &Copy the following into
/etc/init.d/vncserver. The easiest way to do it is to copy it to your clipboard, runsudo -i && cat > /etc/init.d/vncserver && exitin a terminal, paste it in, and type CTRL-D. Be sure to change the USER variable to whatever user you want the VNC server to run under.#!/bin/sh -e ### BEGIN INIT INFO # Provides: vncserver # Required-Start: networking # Default-Start: 3 4 5 # Default-Stop: 0 6 ### END INIT INFO PATH="$PATH:/usr/X11R6/bin/" # The Username:Group that will run VNC export USER="mythtv" #${RUNAS} # The display that VNC will use DISPLAY="1" # Color depth (between 8 and 32) DEPTH="16" # The Desktop geometry to use. #GEOMETRY="<WIDTH>x<HEIGHT>" #GEOMETRY="800x600" GEOMETRY="1024x768" #GEOMETRY="1280x1024" # The name that the VNC Desktop will have. NAME="my-vnc-server" OPTIONS="-name ${NAME} -depth ${DEPTH} -geometry ${GEOMETRY} :${DISPLAY}" . /lib/lsb/init-functions case "$1" in start) log_action_begin_msg "Starting vncserver for user '${USER}' on localhost:${DISPLAY}" su ${USER} -c "/usr/bin/vncserver ${OPTIONS}" ;; stop) log_action_begin_msg "Stoping vncserver for user '${USER}' on localhost:${DISPLAY}" su ${USER} -c "/usr/bin/vncserver -kill :${DISPLAY}" ;; restart) $0 stop $0 start ;; esac exit 0Make the script executable with
sudo chmod +x /etc/init.d/vncserver.- Finally, connect to your server with a VNC client on port 590X, where X is the value of "DISPLAY" in the vncserver script. On OS X, I like to use Chicken of the VNC. On Windows and Linux, the TightVNC client works nicely.
2707974
- 10,758
