I want to build a simple GUI for an app that use bash so for example clicking on a button would execute some bash commands and so one.
There's a GUI creator also simple, i need only buttons and textareas that doesn't require to learn a new programming launguage?
I posted an answer here, that may be useful, for convenience I will just put it here again.
Yad may be useful in this regard, it is a fork of zenity with more features, one of them the ability to create forms.
Here is a very simple example of a form:
#!/bin/bash
frmdata=$(yad --title "Test Form" --form --field "Address" --field="Name")
frmaddr=$(echo $frmdata | awk 'BEGIN {FS="|" } { print $1 }')
frmname=$(echo $frmdata | awk 'BEGIN {FS="|" } { print $2 }')
echo $frmaddr > test.txt
echo $frmname >> test.txt
The above script will display a form like this:
After you enter your data and click ok or hit enter on the keyboard, the form data will be written to a text file called test.txt, I am using awk to separate the form data which is a string with a pipe as field separator, I believe there is a direct way to get the data without awk but I am no yad expert, please check the project home and ask questions, you may find a more elegant way.
How to get and install yad here:
http://www.webupd8.org/2010/12/yad-zenity-on-steroids-display.html
yad project home:
http://code.google.com/p/yad/
more examples here:
http://technostripe.com/yad-a-fork-of-zenity-with-more-features/
http://code.google.com/p/yad/wiki/Examples
There is no form designer for it yet but since the syntax is so simple and so close to zenity, that is not usually a problem.
Sabacon
  • 41,474
For simple user-input you can use zenity (lives in the zenity package). A simple example might be something like this:
VARIABLE=$(zenity --entry --title="Give me inputz" --text="Write some stuff")
echo $VARIABLE
For a textarea (as we'd say in the HTML world), you'd change the syntax to something like this:
zenity --text-info --title="Give me inputz" --editable
You can find out a lot more from its manual. It's a very flexible little library user input in simple scripts.
Edit: You can also find some good examples over at Linuxaria.
Oli
  • 299,380
Take a look at this: http://sites.google.com/site/easybashgui
You use:
source easybashgui
input 2 "Address" "?" "Name" "?"
cp "$dir_tmp/$file_tmp" "test.txt"
clean_temp
Yi Jiang
  • 1,206
Try tkbash.
You can specify elements like this
tkbash 1 button b1 -x 0 -y 0 -w 100 -h 30 -t "click me" --command "notify-send hi"
phil294
  • 639
