I'm having trouble with the update manager. Normal install gets me:
~$ sudo apt-get install
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these.
ffmpeg : Depends: libvdpau1 (>= 0.2) but it is not installed
mesa-vdpau-drivers : Depends: libvdpau1 but it is not installed
vdpau-va-driver : Depends: libvdpau1 (>= 0.2) but it is not installed
E: Unmet dependencies. Try using -f.
with the recommended option:
~$ sudo apt-get -f install
Correcting dependencies... Done
The following additional packages will be installed:
libvdpau1
The following NEW packages will be installed:
libvdpau1
0 upgraded, 1 newly installed, 0 to remove and 2 not upgraded.
6 not fully installed or removed.
Need to get 0 B/25,5 kB of archives.
After this operation, 100 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database ... 235502 files and directories currently installed.)
Preparing to unpack .../libvdpau1_1.1.1-3ubuntu1_amd64.deb ...
Unpacking libvdpau1:amd64 (1.1.1-3ubuntu1) ...
dpkg: error processing archive /var/cache/apt/archives/libvdpau1_1.1.1-3ubuntu1_amd64.deb (--unpack):
trying to overwrite shared '/etc/vdpau_wrapper.cfg', which is different from other instances of package libvdpau1:amd64
Processing triggers for libc-bin (2.23-0ubuntu3) ...
Has anyone got any idea what the problem might be? I've tried all solutions to similar problems on here and none is working.
