I am getting a java.io.FileNotFoundException when trying to update PyCharm/IntelliJ:
  1. Ubuntu 16.04.
  2. Installed PyCharm as per GetDeb in https://askubuntu.com/a/701656/631904.
  3. It says it wants to update from PyCharm 2016.3.2 to 2016.3.3. It says I do not have write access to /usr/share/pycharm. So I run sudo pycharm. After Downloading Patch File and "Some conflicts were found in the installation area" where its "Solution" is "IGNORE" I click Proceed.
Get "Failed to Apply Patch":
Temp. directory: /root/.PyCharmCE2016.3/system/tmp/patch-update
java.io.FileNotFoundException: /root/.PyCharmCE2016.3/system/log/idea.updater.files.tmp.0/temp.tmp.1/bin/pycharm.png (No such file or directory)
at java.io.FileInputStream.open0(Native Method)
at java.io.FileInputStream.open(FileInputStream.java:195)
at java.io.FileInputStream.<init>(FileInputStream.java:138)
at com.intellij.updater.Utils.newFileInputStream(Utils.java:260)
at com.intellij.updater.UpdateAction.doApply(UpdateAction.java:65)
at com.intellij.updater.PatchAction.apply(PatchAction.java:201)
at com.intellij.updater.Patch.lambda$apply$2(Patch.java:323)
at com.intellij.updater.Patch.forEach(Patch.java:372)
at com.intellij.updater.Patch.apply(Patch.java:321)
at com.intellij.updater.PatchFileCreator.apply(PatchFileCreator.java:84)
at com.intellij.updater.PatchFileCreator.apply(PatchFileCreator.java:76)
at com.intellij.updater.Runner.doInstall(Runner.java:303)
at com.intellij.updater.Runner.lambda$install$0(Runner.java:272)
at com.intellij.updater.SwingUpdaterUI.lambda$doPerform$4(SwingUpdaterUI.java:190)
at java.lang.Thread.run(Thread.java:745)
I think IntelliJ is involved because that is a default for the editor settings.
JonBrave
  • 699
