For whatever reason VLC disappeared. I really can't remember if it were something I did or some weird update. Whatever the case the program wasn't opening but I could see that it was still installed. I purged it and I've been trying to get it re-installed ever since.
sudo apt install vlc gives the following output:
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies.
vlc : Depends: libgles1-mesa (>= 7.8.1) but it is not going to be installed or
libgles1
This didn't feel right. So I google broken package errors for solutions and most commonly it was running sudo apt clean or doing it from within Synaptic. I've done both to no avail.
Next I assume the package does need to be installed, I open up Synaptic and search for this libgles... find the packages, hit install...error. This package depends on libglapi-mesa, I search for it and find that it's already installed. At this point I've followed the rabbit hole and don't know where to go now.
