I am currently on ubuntu 14.04 and I am trying to download steam launcher but when I try I get a screen that reads.
"The package system is broken
 Check if you are using third party repositories. If so disable them, since they are a common source of problems.
Furthermore run the following command in a Terminal: apt-get install -f"
and when I open details it reads.
"The following packages have unmet dependencies:
linux-image-extra-3.13.0-73-generic: Depends: linux-image-3.13.0-73-generic but it is not installed
linux-image-generic: Depends: linux-image-3.13.0-73-generic but it is not installed"
Please Help Thank You.
Filesystem                          Size  Used Avail Use% Mounted on
udev                                914M  4.0K  914M   1% /dev
tmpfs                               185M  940K  184M   1% /run
/dev/mapper/ubuntu--kylin--vg-root  292G   43G  235G  16% /
none                                4.0K     0  4.0K   0% /sys/fs/cgroup
none                                5.0M     0  5.0M   0% /run/lock
none                                924M  184K  924M   1% /run/shm
none                                100M   44K  100M   1% /run/user
/dev/sda1                           236M  236M     0 100% /boot
izzy-22@Randys-PC:~$
George Udosen
  • 37,534
It looks like your problem is that some of your packages depend on other ones and this is causing apt to get stuck. I'd say open terminal and run sudo apt install linux-image-3.13.0.73-generic, because that package is not installed and seems to be the cause of the problems. Just install that package and then report back whether it worked. It should resolve that dependency error.
Now looking at edits in the question, your /boot is full, so try running,
sudo apt-get autoremove
to remove old kernels and initrds stored there. Then run
sudo apt-get install linux-image-3.13.0.73-generic.
This should fix the dependency problems
spark
  • 658
  • 15
