Just had a similar issue on ubuntu 22.04:
apt upgrade
Reading package lists... Done
Building dependency tree... Done
Calculating upgrade... Done
Try Ubuntu Pro beta with a free personal subscription on up to 5 machines.
Learn more at https://ubuntu.com/pro
The following packages have been kept back:
grub-efi-amd64-bin grub-efi-amd64-signed
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
https://itsfoss.com/following-packages-have-been-kept-back/ describes the reason and the solution quite well:
Normally, when you run the sudo apt update and sudo apt upgrade commands, it updates all the installed packages to their available newer versions.
However, if the dependencies of an installed package have been changed such that it requires installation of new packages, the installed package won’t be upgraded with the system update and you’ll see package kept back error.
The solution is to run
sudo apt install --only-upgrade grub-efi-amd64-bin
The following additional packages will be installed:
The following packages will be upgraded:
2 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 1.272 kB of archives.
After this operation, 15,4 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Get:1 http://de.archive.ubuntu.com/ubuntu jammy-updates/main amd64 grub-efi-amd64-signed amd64 1.182~22.04.1+2.06-2ubuntu10 [533 kB]
Get:2 http://de.archive.ubuntu.com/ubuntu jammy-updates/main amd64 grub-efi-amd64-bin amd64 2.06-2ubuntu10 [740 kB]
Fetched 1.272 kB in 0s (3.210 kB/s)
(Reading database ... 238324 files and directories currently installed.)
Preparing to unpack .../grub-efi-amd64-signed_1.182~22.04.1+2.06-2ubuntu10_amd64.deb ...
Unpacking grub-efi-amd64-signed (1.182~22.04.1+2.06-2ubuntu10) over (1.180+2.06-2ubuntu7) ...
Preparing to unpack .../grub-efi-amd64-bin_2.06-2ubuntu10_amd64.deb ...
Unpacking grub-efi-amd64-bin (2.06-2ubuntu10) over (2.06-2ubuntu7) ...
Setting up grub-efi-amd64-bin (2.06-2ubuntu10) ...
Setting up grub-efi-amd64-signed (1.182~22.04.1+2.06-2ubuntu10) ...
Trying to migrate /boot/efi into esp config
Installing grub to /boot/efi.
Installing for x86_64-efi platform.
Installation finished. No error reported.
