I'm trying to install Vundle following the instruction from here , but when I use the command, vim +PluginInstall +qall terminal shows this:
Error detected while processing /home/scorpion/.vimrc:
line 6:
E117: Unknown function: vundle#begin
line 11:
E492: Not an editor command: Plugin 'VundleVim/Vundle.vim'
line 16:
E492: Not an editor command: Plugin 'tpope/vim-fugitive'
line 18:
E492: Not an editor command: Plugin 'L9'
line 20:
E492: Not an editor command: Plugin 'git://git.wincent.com/command-t.git'
line 22:
E492: Not an editor command: Plugin 'file:///home/gmarik/path/to/plugin'
line 25:
E492: Not an editor command: Plugin 'rstacruz/sparkup', {'rtp': 'vim/'}
line 28:
E492: Not an editor command: Plugin 'ascenator/L9', {'name': 'newL9'}
line 31:
E117: Unknown function: vundle#end
Press ENTER or type command to continue
I'm new at this . What is the possible problem here ? How could I solve them?
How could I be ensure that my Vundle is installed properly ?
content of .vimrc is
set nocompatible " be iMproved, required
filetype off " required
" set the runtime path to include Vundle and initialize
set rtp+=~/.vim/bundle/Vundle.vim
call vundle#begin()
" alternatively, pass a path where Vundle should install plugins
"call vundle#begin('~/some/path/here')
" let Vundle manage Vundle, required
" The following are examples of different formats supported.
" Keep Plugin commands between vundle#begin/end.
" plugin on GitHub repo
" plugin from http://vim-scripts.org/vim/scripts.html
Plugin 'L9'
" Git plugin not hosted on GitHub
" git repos on your local machine (i.e. when working on your own plugin)
" Plugin 'file:///home/gmarik/path/to/plugin'
" The sparkup vim script is in a subdirectory of this repo called vim.
" Pass the path to set the runtimepath properly.
" Install L9 and avoid a Naming conflict if you've already installed a
" different version somewhere else.
" All of your Plugins must be added before the following line
call vundle#end() " required
filetype plugin indent on " required
" To ignore plugin indent changes, instead use:
"filetype plugin on
" Brief help
" :PluginList - lists configured plugins
" :PluginInstall - installs plugins; append `!` to update or just :PluginUpdate
" :PluginSearch foo - searches for foo; append `!` to refresh local cache
" :PluginClean - confirms removal of unused plugins; append `!` to auto-approve removal "
" see :h vundle for more details or wiki for FAQ
" Put your non-Plugin stuff after this line
